Ultra High Speed HDMI 4K120Hz, 8K60Hz  Cable 48Gbps M/M  3 m/ 9.84ft
The Club 3D CAC-1373 Ultra High Speed HDMI™2.1 Cable is built to handle the highest quality video- and audio- signals.
- HDMI™2.1 also supports Static- and Dynamic HDR metadata.
All HDMI™2.1 features are fully supported by this Club3D CAC-1373 Cable. It is the ideal solution for the ultimate future proof HDMI™2.1 experience.
Ultra High Speed HDMI 4K120Hz, 8K60Hz  Certified Cable 48Gbps M/M  1 m/3.28 ft
Ultra High Speed HDMI 4K120Hz, 8K60Hz  Certified Cable 48Gbps M/M  1.5 m/4.92 ft
Product Name: Ultra High Speed HDMI™ 4K120Hz, 8K60Hz Cable 48Gbps M/M 3 m/9.84ft
Product Series: Cable
Product Code: CAC-1373
EAN code: 8719214471378
UPC code: 841615101566
• Fully Compliant to the Ultra High Speed HDMI™2.1 specification
• Professional quality cable
• Low EMI emission
• Gold plated connectors for maximum conductivity and 28 AWG
• Enhanced gaming and media features
• Color space BT.2020 with 10bits,12bits,16bits
• Supports (U)HD resolutions up to 4K120Hz (with DSC 1.2) or 8K60Hz
• Supports Static- and Dynamic- HDR Metadata
• All
•1x Ultra High Speed HDMI™ 4K120Hz, 8K60Hz Certified Cable 48Gbps M/M
• HDMI™ Male
• HDMI™ Male
• Box size: 17.5 x 17.5 x 4.5 cm / 6.89 x 6.89 x 1.77 inch
• Cable length approx.: 3 m/9.84 ft
• Connector dimensions: 5 x 2 x 1 cm / 1.97 x 0.79 x 0.39 inch
• Cable Weight: 216gr / 7.62 oz
• Box Weight: 62 gr / 2.19 oz
• LDPE Bag Weight: 9 gr / 0.32 oz
• Total Weight: 282 gr / 9.95 oz
Note:
