DisplayPort 1.4 to HDMI 4K120Hz HDR Active Adapter M/F
The Club 3D CAC-1085 is the perfect solution to connect to any HDMI™ 4K120Hz ready displays*. If you have a DisplayPort™ 1.4 ready PC or any other device that lacks the new HDMI™ 4K120Hz specification, the Club3D CAC-1085 will be the simple way to upgrade your device and connect to your new TV*.
With its DP1.4 DSC video compression technology, this adapter is able to convert DP1.4 video signals to HDMI™2.1, supporting video display resolutions up to 8K (7680 x 4320)@60Hz ** and creating life like colors and movements with HDR giving users the ultimate visual experience. The Adapter is powered thru an USB Type C to USB Type A cable(provided with the product).
* Please update your TV Firmware to the version which supports these resolutions/refresh rates !
** Please update your Graphic drivers on your PC and make sure that DSC1.2 is supported on your devices to support the these resolutions/refresh rates!
In case you need assistance to choose the correct cable, please visit our
website www.club-3d.com or feel free to mail us at [email protected] and it will be our pleasure to assist you.
Ultra High Speed HDMI™ Cable 10K 120Hz 48Gbps M/M 1 m./3.28 ft.
Ultra High Speed HDMI™ Cable 10K 120Hz 48Gbps M/M 2 m./6.56 ft.
Product Name: DisplayPort™1.4 to HDMI™ 4K120Hz HDR Active adapter M/F
Product Series: Adapter
Itemcode: CAC-1085
EAN code: 8719214471538
UPC code: 841615101726
• Compliant with VESA DisplayPort™ v1.4 Specification
• Compliant with HDMI™ v2.1 Specification
• Support HDCP 1.4 and HDCP2.2
• Support Max. resolution/refresh rates up to [email protected]
• Support Dynamic HDR
• Sound Support 5.1-7.1
Applications:
• For the host device like laptop, desktop, video converter adaptor, docking station, projector, gaming and display system like TV*, digital signage, VR/AR system.
• Perfect for Host Devices which are featured with the DP1.4 graphic card that supports DP video signal output for gaming, commercial applications**.
Supported resolutions:
• Support Max. resolution/timing up to [email protected]
• CAC-1085 Active Adapter
• USB Type A to USB Type C Cable for external power
• 1x DP1.4 (Male)
• 1x USB Type C to USB Type A for power (5V/1.5A)
• 1x HDMI™ (Female)
Note: Cable should meet 8K60Hz specs(or above) and should not exceed 2 m / 6.56 ft
• Box size: 25 x 7.5 x 3.5 cm / 9.85 x 2.96 x 1.38 inch
• Device size: 6.2 x 4.7 x 1.9 cm / 2.45 x 1.85 x 0.75 inch
• Output Cable length approx.: 15 cm / 5.9 inch
• USB (Power) Cable length approx.: 50 cm / 19.64 inch
• Connector dimensions:
- DisplayPort™ Male 4.5 x 2 x 1.5 cm / 1.78 x 0.79 x 0.6 inch
- USB Type C Male 2.9 x 1.2 x 0.7 cm / 1.15 x 0.5 x 0.28 inch
- USB Type A Male 3.8 x 1.5 x 0.8 cm / 1.5x 0.6 x 0.32 inch
• Device Weight: 56 gr / 2 oz
• USB Cable Weight: 28 gr / 1 oz
• Box Weight: 31 gr / 1.1 oz
• LDPE Bag Weight: 5gr / 0.18 oz
• Total Weight: 120 gr / 4.3 oz
This product is SPECIFICALLY designed to work with the latest Graphics Processing Units (GPU’s) which supports DSC 1.2. At the time of printing, these are the supported GPUs:
AMD™ NAVI: RX5700, RX5600XT, RX5700XT, RADEON VII, RX5500XT.
NVIDIA TURING™ RTX : TITAN RTX , RTX 2080, RTX 2070, RTX 2060
Intel™ Eleven Based Gen: IceLake, Iris Plus Graphics, UHD Graphics
Please make absolutely sure that you’re using one of the above mentioned graphical technologies in order to obtain the Superior functionality of our Club 3D CAC-1085.
This adapter will function with lower specifications GPU’s, be aware performance will be reduced due to the specifications of that GPU !!
Functionality is also dependent on the HDMI™ M/M cable used. In combination with this CAC-1085 adapter, we advise using HDMI™ Male/Male cable of 28AWG Quality or
above, like the Club 3D CAC-1371 and/or CAC-1372 up to 2m/ 6.56 ft max. !
In case you need assistance to choose the correct cable, please visit our website www.club-3d.com or feel free to mail us at [email protected]
No extra information found.
