HDMI 1.4 to VGA Adapter with Audio M/F
The Club 3D CAC-1302 is an active HDMI™ 1.4 to VGA signal converter. It allows you to convert digital HDMI™ signal into analog VGA signal and extracts audio signal from HDMI™ signal through the R/L audio port.
Besides, if the HDMI™ source display can’t supply enough power, you can connect a power adapter or computer to the Micro USB female port to supply power for the adapter.
Product Name: |
HDMITM 1.4 to VGA Adapter with Audio M/F |
Product Series: Adapter |
Product Code: CAC-1302 |
EAN code: 8719214471668 |
UPC code: 841615101870 |
This product has many features that enable it to perform in a superior manner. Among those features you will find: |
• Support HDMI™ A and Micro USB input, VGA and Stereo audio output |
• Support HDMI™ resolutions up to 1080p@60HZ, HDMI™ Bandwidth 165MHZ/1.65Gbps per channel (4.95Gbps for all channels) |
• Support VGA resolutions up to 1080p@60HZ |
• Support analog audio format |
• Easy to Use: Install in seconds, no need of setting. |
• Support HDCP |
OS Support: All |
• CAC-1302 HDMI™ 1.4 to VGA Adapter with Audio (Jack 0.35cm / 0.14inch) |
• USB Power Cable (± 50cm / 19.9inch) |
Available Interfaces |
• HDMI™ 1.4 Type A, Micro USB |
• VGA and Stereo Audio (analog) |
• Box size: 6 x 24 x 3.5cm / 2.36 x 9.45 x 1.38 inch |
• Device size: 24 x 4.3x 1.45 cm / 9.5 x 1.69 x 0.57 inch |
• Output Cable length approx.: 16 cm / 6.3 inch |
• USB (Power) Cable length approx.: 50 cm / 19.69 inch |
• Connector dimensions: |
- Unit 4.5 x 4.3x 1.45 cm / 1.77 x 1.69 x 0.57 inch |
• Device Weight: 28 gr / 0.99 oz |
• USB Cable Weight: 14 gr / 0.49 oz |
• Box Weight: 28 gr / 0.99 oz |
• LDPE Bag Weight: 6 gr / 0.211 oz |
• Total Weight: 76 gr / 2.68 oz |
- CAC-1302_SPECIFICATION-SHEET_New_EN.pdf
- CAC-1302_SPECIFICATION-SHEET_New_DE.pdf
- CAC-1302_SPECIFICATION-SHEET_New_ES.pdf
- CAC-1302-QUICK INSTALL-GUIDE_EN.pdf
- CAC-1302-QUICK INSTALL-GUIDE_DE.pdf
