DisplayPort 1.4 Active Optical Cable Unidirectional  4K120Hz 8K60Hz M/M  20m/65.62ft
The Club 3D CAC-1079 is an Active Optical Unidirectional DisplayPort™ Cable that allows support for 8.1Gbps per channel. It supports 4K at 120Hz resolution as well as 8K at 60Hz and HDR formats.
DisplayPort™ 1.4 adds support for Display Stream Compression 1.2 (DSC), Forward Error Correction, and extends the maximum number of inline audio channels to 32.
This optical fiber cable can be applied to outdoor displays, LED signboards, home cinema displays, conference rooms, medical imaging equipment or security systems to transfer audio and video signals.
Multi Stream Transport (MST) Hub DisplayPort 1.4 Triple Monitor
USB3.2 Gen1 Type A or C Dual Display 4K60Hz Docking Station
DisplayPort™ 1.4 Active Optical Cable Unidirectional 4K120Hz 8K60Hz M/M 20m/65.62ft
Product Series: Cable
Product Code: CAC-1079
EAN code: 8719214471736
UPC code: 841615101962
This product has many features that enable it to perform in a superior manner. Among those features you will find;
• Support 4K at 120Hz or 8K at 60Hz and HDR formats • Supports HBR3, HDCP1.4/2.2
• Supports DP 1.4 standard with bandwidth of up to 8.1Gps per channel - total bandwidth of 32.4Gbps • Support resolutions up to 8K @ 60Hz and 4K @ 144Hz
• Without DSC1.2 max resolution supported up to: - 5K @ 60Hz
• Support length of 20m/65.62ft*
• Maximum Pixel clock frequency is 810 Mhz
• OD 4.8 mm
• Uni-directional - Meaning Source and Display Only
• This cable is Hybrid which means it is downwards compatible to other DisplayPort™ versions
• No external power supply is required
• Plug and Play no driver software required
* A maximum of 100m/328ft - please contact Club 3D
• DisplayPort™ 1.4 Active Optical Cable Uni-directional 4K120Hz 8K60Hz M/M 20m/65.62ft
• DisplayPort™ 1.4
Source Connection Male
• DisplayPort™ 1.4
Display Connection Male
• Box size: 23 x 23 x 5 cm / 9 x 9 x 1.97 inch
• Cable length approx.: 20m/65.62ft
• Connector dimensions: 4.5 x 2.1 x 1.1 cm / 1.77 x 0.83 x 0.43 inch
• Cable Weight: 656 gr / 23.14 oz
• Box Weight: 110 gr / 3.88 oz
• LDPE Bag Weight: 11 gr / 0.39 oz
• Total Weight: 777 gr / 27.4 oz
