HDMI to USB C 4K60Hz Active Adapter M/F
The Club 3D CAC-1332 is an HDMI™ to USB C Active adapter which allows you to transmit an HDMI™ Signal into a USB C DisplayPort supported Display.This product supports resolutions of up to [email protected] This adapter is Uni-Directional it only works from an HDMI™ Source device to an USB C DisplayPort supported display. It is equipped with an USB micro USB to supply power, the maximum power needed is 5V/1A.
Please use one of our extension cables to connect from the adapter to your devices - such as the CAC-1522 or the CAC-1535 - you can find more information at www.club-3d.com or contact us at [email protected]
Product Name: |
HDMI™ to USB C 4K60Hz Active Adapter M/F |
Product Series: Adapter |
Product Code: CAC-1332 |
EAN code: 8719214471743 |
UPC code: 841615101979 |
This product has many features that enable it to perform in a superior manner. Among those features you will find: |
• HDMI™ 2.0 support : |
- HDCP 1.4 /2.2 |
- 8/10/12/ Bit Deep Color |
- Status and Control Data Channel (SCDC) |
• Professional quality Adapter |
• This Adapter is Uni - Directional because its an Active Adapter. |
• Backwards compatible to earlier HDMI™ versions, however supported resolutions will be limited to the versions |
• Supports resolution up to 4K60Hz |
• Supports Hot Plug Detect |
• Gold plated connectors |
• Bundled with a USB A to Micro USB cable |
for External power support - 5V/1A |
• ABS Housing material |
• All |
• HDMI™ to USB C 4K60Hz Active Adapter M/F |
• USB A to Micro USB Power Cable 1 m/3.28 ft |
Available Interfaces |
• HDMI™ Type A Male |
• Micro USB Female |
• USB Type C Female |
• Box size: 14.5 x 14.5 x 4.5cm 5.71 x 5.71 x 1.77 inch |
• Device size: 25. 2 cm / 9.92 inch |
• USB (Power) Cable length approx.: 1 m/3.28 ft |
• Connector dimensions: |
- Unit: 7.15 x 3.11 x 1.2 cm / 2.81 x 1.22 x 0.47 inch |
- HDMI™ Connector: 2.1 x 1.76 x.0.83 cm / 0.83 x.0.69 x 0.33 inch |
• Device Weight: 29 gr / 1.02 oz |
• USB Cable Weight: 21 gr / 0.75 oz |
• Box Weight: 45 gr / 1.59 oz |
• LDPE Bag Weight: 8 gr / 0.28 oz |
• Total Weight: 103 gr / 3.63 oz |
- CAC-1332_SPECIFICATION-SHEET_EN.pdf
- CAC-1332_SPECIFICATION-SHEET_DE.pdf
- CAC-1332_SPECIFICATION-SHEET_ES.pdf
- CAC-1332-QUICK INSTALL-GUIDE_EN.pdf
- CAC-1332-QUICK INSTALL-GUIDE_DE.pdf
