Ultra High Speed HDMI 4K120Hz, 8K60Hz  Certified Cable 48Gbps M/M  1.5 m/4.92 ft
The Club 3D CAC-1370 Ultra High Speed HDMI™2.1 Certified Cable is built to handle the highest quality video- and audio- signals.
The increase in maximum bandwidth compared to previous versions is achieved by increasing both the bitrate of the data channels (from 6Gbps to 12Gbps) and the number of channels (from 3 to 4). This allows support for resolutions up to 8K at 60Hz! New feature included in this Specification is Display Stream Compression (DSC) 1.2, which is used for video formats higher than 8K with 4:2:0.
- HDMI™2.1 also supports Static- and Dynamic- HDR metadata.
All HDMI™2.1 features are fully supported by this Club3D CAC-1370 Cable. It is the ideal solution for the ultimate future proof HDMI™2.1 experience.
* Please check your TV/monitor user manual for its required specifications and maximum resolutions.
Ultra High Speed HDMI 4K120Hz, 8K60Hz  Cable 48Gbps M/M  3 m/ 9.84ft
HDMI 2.0 UHD Active Optical Cable HDR 4K 60Hz M/M 50m/164,04ft
Ultra High Speed HDMI™ 4K120Hz, 8K60Hz Cable 48Gbps M/M 1.5 m /4.92ft
Product Series: Cable
Product Code: CAC-1370
EAN code: 8719214471750
UPC code: 841615101986
• Fully Compliant to the Ultra High Speed HDMI™2.1 Certified specification
• Professional quality cable
• Low EMI emission
• Gold plated connectors for maximum conductivity and 28 AWG
• Enhanced gaming and media features
• Color space BT.2020 with 10bits,12bits,16bits
• Supports (U)HD resolutions up to 4K120Hz (with DSC 1.2) or 8K60Hz
• Supports Static- and Dynamic- HDR Metadata
• All
• 1x Ultra High Speed HDMI™ 4K120Hz, 8K60Hz Certified Cable 48Gbps M/M
• HDMI™ Male
• HDMI™ Male
• Box size: 14.5 x 14.5 x 4.5 cm / 5,71 x 5,71 x 1,77 inch
• Cable length approx.: 1.5 m /4.92ft
• Connector dimensions: 5 x 2 x 1 cm / 1.97 x 0.79 x 0.39 inch
• Cable Weight: 93 gr / 3.28 oz
• Box Weight: 46 gr / 1.62 oz
• LDPE Bag Weight: 4 gr / 0.14 oz
• Total Weight: 143 gr / 5.04 oz
Note:
POSSIBLE RESOLUTIONS
