USB Gen2 Type-C to Type-A Cable 10Gbps M/F 5m/16.4ft
The Club 3D CAC-1536 USB Gen2 Type-C to Type-A Cable 10Gbps M/F 5m/16.4ft cable connects your Notebook, Tablet or Phone with USB Type-C output to your favorite existing Peripherals, Accessories and Chargers featuring the common USB Type-A plug. It enables Data and Power over a single cable. This cable supports USB 3.2 Gen 2. SuperSpeed+ data up to 10Gbps and up to 900mA output for Downstream charging or powering your USB Type-A enabled Notebook, Tablet or Smartphone.
USB 3.1 Type-C to Type-A Cable 10Gbps PD 60W M/M 1m/3.28ft
USB 3.2 Gen2 Type C to C Active Bi-directional Cable 8K60Hz  M/M 5m/16.4ft
Product Series: Cables
Product Code: CAC-1536
EAN code: 8719214472078
UPC code: 841615102303
• USB Gen2 SuperSpeed+ Data up to 10Gbps
• USB Gen2 Data and Charging through a single cable
• USB Power, max. 900mA Downstream charging to USB Type-A device
• Works with all USB Type-C enabled devices
• Output connector USB Type-A Female
• Unidirectional
• Works with Windows 10 or upwards, Mac 13.5.2
• Windows 10 or upwards, Mac 13.5.2
• CAC-1536 USB Gen2 Type-C to Type-A Cable 10Gbps M/F 5m/16.4ft
• USB Type-C Male
• 1x USB Type-A Female
• Box size: 17.5 x 17.5 x 4.5cm 6.89 x 6.89 x 1.77"
• Total Cable length approx.: 5 m / 16.4 ft
• USB Type-C Male Connector dimensions: 4.6 x 1.24 x 0.63 cm / 1.81 x 0.48 x 0.24"
• USB Type-A Female Connector dimensions: 5 x 2.25 x 1.15 cm / 1.97 x 0.88 x 0.45"
• Cable Weight: 165 gr / 5.82 oz
• Box Weight: 63 gr / 2.22 oz
• Total Weight: 228 gr / 8.04 oz
