USB Gen2 Type-C to 10Gbps 4x USB Type-A Hub
The Club 3D CSV-1547 is an USB Gen2 Type-C to four USB Type-A ports hub, which adds four common USB Type-A ports to your USB Type-C 10G enabled device for Data and Charging. It can work on any Type-C host ( PC, notebook, tablet, Mobile phone,etc). Works with all major Operating Systems.
Product Name: |
USB Gen2 Type-C to 10Gbps 4x USB Type-A Hub |
Product Series: Universal Docking |
Product Code: CSV-1547 |
EAN code: 8719214472375 |
UPC code: 841615102624 |
• Support USB Type-C input, four USB Type-A outputs |
• Max 900mA per port (only one port is connected), when two or more ports are connected at the same time, the total max output depends on the host PC (eg, max 900mA on Chromebook, max 1.5A on Macbook) |
• Support USB Gen2 (10Gbps) transmission, downward compatible USB3.0 & USB2.0 |
• USB port supports to charge and transmit data for the USB device simultaneously |
• USB Type-C port supports plug and play, hot swap |
• No external Power needed(Powered thru USB Type-C host connection) |
• Easy to carry and use |
• Sturdy and compact aluminium casing |
• All |
• CSV-1547 USB Gen2 Type-C to 10Gbps 4x USB Type-A Hub |
Available Interfaces |
• USB Type-C Male |
• 4x USB Type-A Female |
• Box size: 7 x 32 x 3.5cm 2.76 x 12.6 x 1.38 " |
• Device size: 9.5 x 4.5 x 1.15 cm / 3.74 x 1.77 x 0.45" |
• USB Host Cable length approx.: 16.7 cm / 6.57" |
• Total length approx.: 26.2 cm / 10.31" |
• USB Type-C Male Connector dimensions: .4 x 1.2 x 0.7cm / 1.34 x 0.47 x 0.28" |
• Device Weight: 63 gr / 2.22 oz |
• Box Weight: 42 gr / 1.48 oz |
• Total Weight: 110 gr / 3.88 oz |
- CAC-1547_SPECIFICATION-SHEET_EN.pdf
- CAC-1547_SPECIFICATION-SHEET_DE.pdf
- CAC-1547_SPECIFICATION-SHEET_ES.pdf
