DisplayPort 1.4 to HDMI 4K120Hz or 8K60Hz HDR10 Cable M/M 3m/9.84ft
The Club 3D CAC-1087 is the perfect solution to connect to any HDMI™ 4K120Hz or 8K60Hz ready displays*. If you have a DisplayPort™ 1.4 ready PC or any other device that lacks the new HDMI™ 4K120Hz or 8K60Hz specification, the Club3D CAC-1087 will be the simple way to upgrade your device and connect to your new TV*.
With its DP1.4 DSC video compression technology, this adapter is able to convert DP1.4 video signals to HDMI™, supporting video display resolutions up to 8K (7680x4320/60HZ or 3840x2160/120Hz) and creating life like colors and movements with HDR10 giving users the ultimate visual experience. The Adapter is powered thru the DP™ port.
DisplayPort 1.4 to HDMI 4K120Hz HDR Active Adapter M/F
Mini DisplayPort 1.4 to HDMI 4K120Hz with DSC1.2 Active Adapter M/F
DisplayPort™ 1.4 to HDMI™ 4K120Hz or 8K60Hz HDR10 Cable M/M 3m/9.84ft
Product Series: Cable
Product Code: CAC-1087
EAN code: 8719214472436
UPC code: 841615102709
• Compliant with VESA DisplayPort™ v1.4 Specification
• Compliant with HDMI™ 2.1 Specification
• Support both HDCP 1.4 and HDCP 2.2
• Support Max. resolution/refresh rates up to 4K120Hz or 8K60Hz
• Support Dynamic HDR10
Applications:
• For the host device like laptop, desktop, video converter adaptor, docking station, projector, gaming and display system like TV*, digital signage, VR/AR system.
• Perfect for Host Devices which are featured with the DP1.4 graphic card that supports DP video signal output for gaming, commercial applications**.
Supported resolutions:
• Support Max. resolution/timing up to 4K120Hz or 8K60Hz
This adapter will function with lower specifications GPU’s, be aware performance will be reduced due to the specifications of that GPU !!
• Microsoft, Mac OS
• CAC-1087 DisplayPort™ 1.4 to HDMI™ 4K120Hz or 8K60Hz HDR10 Cable M/M 3m/9.84ft
• 1x DP1.4 (Male)
• 1x HDMI™ (Male)
• Box size: 21 x 21 x 3.5 cm / 8.27 x 8.27 x 1.38"
• Cable Length : 3m / 9.84ft
• Connector dimensions:
 - DisplayPort™ Male 4.5 x 2 x 1.5 cm / 1.78 x 0.79 x 0.6 "
 - HDMI™ Male 6.3 x 2 x 1.1 cm / 2.48 x 0.79 x 0.43"
• Cable Weight: 139 gr / 4.9 oz
• Box Weight: 70 gr / 2.47 oz
• Bag Weight: 5gr / 0.18 oz
• Total Weight: 214 gr / 7.55 oz
Note:
