HDMI + Micro USB to USB Type-C 4K120Hz or 8K30Hz M/F Active Adapter
The Club 3D CAC-1336 is the perfect solution to connect to any USB Type-C 8K30Hz or 4K120Hz ready displays from a HDMI™ source which does supports these resolutions/specifications.
If you have a PC or any other device that lacks the new USB Type-C 8K30Hz or 4K120Hz specifications, the Club3D CAC-1336 will be the simple way to connect your HDMI™ source device to your new USB Type-C 4K120Hz or 8K30Hz display(provided your source supports these resolutions).
The Adapter is powered thru a Micro USB port(5V/1.5A). An USB Type-A to Micro USB M/M 1m / 3.28 ft is supplied in the box.
Note: This adapter will only work on USB Type-C Displays that are self powered !
Please use one of our Club 3D certified Extension/Adapter cables to connect to your devices. For optimal usages of this adapter we highly recommend you to use the CAC-1576 or CAC-1571.
![]() | CAC-1336 QUICK INSTALLATION GUIDE | ![]() | CAC-1336 QUICK INSTALLATION GUIDE |
Product Name: | ||||
HDMI™+ Micro USB to USB Type-C 4K120Hz or 8K30Hz M/F Active Adapter | ||||
Product Series: Adapter | ||||
Product Code: CAC-1336 | ||||
EAN code: 8719214472504 | ||||
UPC code: 841615102754 | ||||
Features: | ||||
• Compliant with USB DP Alt Mode Specifications up to 3840x2160/120Hz or 7680x4320/30Hz | ||||
• Compliant with HDMI™ Specifications up to 3840x2160/120Hz or 7680x4320/30Hz | ||||
• Support Max. resolution/refresh rates up to 4K120Hz or 8K30Hz | ||||
• Adapter is separatly powered thru a Micro USB Female port 7.5Watt (5V/1.5A) | ||||
• USB Type-A to Micro USB M/M 1m / 3.28 ft cable is supplied in the box | ||||
Note: This adapter will only work on USB Type-C Displays that are self powered ! | ||||
Applications: | ||||
• For devices like laptop, desktop, gaming and display systems like TV. | ||||
• Perfect for Host Devices which are featured with video signal output for gaming, commercial applications. | ||||
Supported resolutions: | ||||
• Support Max. resolution/timing up to 4K120Hz or 8K30Hz | ||||
• ONLY games which are designed for 4K120Hz will provide this experience | ||||
This adapter will function with lower specifications GPU’s, be aware performance will be reduced due to the specifications of that GPU !! | ||||
• To achieve these resolutions it is highly recommended to use the CAC-1576 or CAC-1571 in combination with the adapter | ||||
OS Support: | ||||
• Microsoft, Mac OS | ||||
In the box: | ||||
• CAC-1336 HDMI™+ Micro USB to USB Type-C 4K120Hz or 8K30Hz M/F Active Adapter | ||||
• USB Type-A to Micro USB M/M 1m / 3.28 ft cable for powering the adapter | ||||
Available Interfaces | ||||
Input: | ||||
• 1x HDMI™ (Male) | ||||
• 1x Micro USB (Female) | ||||
Output: | ||||
• 1x USB Type-C (Female) | ||||
Other info: | ||||
• Box size 14.5 x 14.5 x 4.5 cm / 5.71 x 5.71 x 1.77" | ||||
• Device size: 7.2 x 3 x 1.2 cm / 2.83 x 1.18 x 0.47" | ||||
• Device Weight: 28 gr / 0.99 oz | ||||
• Total Cable length: Approx. 26 cm / 10.24" | ||||
• Power Cable length: 1m / 3.28 Ft | ||||
• Power Cable Weigth: 21 gr / 0.74 oz | ||||
• LDPE Bag Weight: 5gr / 0.18 oz | ||||
• Connector dimensions : | ||||
- HDMI™ Male: 4 x 0.7 x 1.8 cm / " | ||||
- USB Type-A Male: 3.7 x 0.7 x 1.5 cm / 1.46 x 0.28 x 0.6" | ||||
- Micro USB Male: 2.8 x 0.6 x 1 cm / 1.1 x 0.24 x 0.39" | ||||
• Box Weight: 45 gr / 1.59 oz | ||||
• Total Weight: 99 gr / 3.5 oz | ||||
• Meets ROHS, FCC, and CE EMI requirements | ||||
Note: - Please update your TV Firmware to the version which supports these resolutions/refresh rates ! - Please update your Graphic drivers on your PC and make sure that DSC1.2 is supported on your devices to support the these resolutions/refresh rates! |
Please use one of our Extension/Adapter cables to connect to your devices: In case you need assistance to choose the correct cable, please visit our website www.club-3d.com or feel free to mail us at [email protected] and it will be our pleasure to assist you. | ||||
- CAC-1336_SPECIFICATION-SHEET_EN.pdf
- CAC-1336_SPECIFICATION-SHEET_DE.pdf
- CAC-1336_SPECIFICATION-SHEET_ES.pdf
- CAC-1336-QUICK INSTALL-GUIDE_EN.pdf
