MiniDisplayPort™ to MiniDisplayPort Bi-Directional VESA DP80 Certified Cable M/M 1m/3.28ft
The Club 3D CAC-1165 MiniDisplayPort to MiniDisplayPort DP80™ Coaxial Cable Vesa Certified Cable , 4K240Hz, 8K60Hz or 10K60Hz M/M 1 m/3.28ft enables the connection of your MiniDisplayPort supported (Gaming) PC or Laptop to an (Ultra) High Resolution Monitor or other MiniDisplayPort supported device. MiniDisplayPort 2.1 UHBR10/13.5/20 up till 80 Gbps, also has support for Display Stream Compression 1.2 (DSC), Forward Error Correction, and extends the maximum number of inline audio channels to 32. It features miniDisplayPort™ connector providing NEW contact fingers special designed for these high speeds. The soft UltraFlex jacket protects the cable from bends and deformation damage.
Product Name: MiniDisplayPort to MiniDisplayPort DP80 Bidirectional Vesa Certified Cable 1m/ 3.28 ft |
Product Series: Cable |
Product Code:CAC-1165 |
EAN-Code: 8719214473143 |
UPC-Code: 841615103393 |
• Fully MiniDisplayPort Version 2.1 Compliant, UHBR10/13.5/20 up till 80 Gbps |
• DP80™ Compliant |
• New Mini DP2.1 spec connector |
• Downwards compatible to older MiniDisplayPort standards |
• Support resolutions up to 4K240Hz or 8K60Hz or 10K60Hz |
• Fully Bidirectional |
• VESA Certified |
Supported resolutions: |
• Up to 4K240Hz, 8K60Hz or 10K60Hz |
• All |
Available Interfaces: |
• MiniDisplayPort DP80 Male |
• 1X CAC-1165 MiniDisplayPort to MiniDisplayPort DP80 Bidirectional Vesa Certified Cable 1m/ 3.28 ft |
• Box size: 14.5 x 14.5 x 4.5 cm / 5.74 x 5.71 x 1.77" |
• Cable length approx.: 1m / 3.28 ft |
• Connector dimensions: |
- MiniDisplayPort- 4.3 x 1.2 x 0.6 cm / 1.7 x 0.47 x 0.23 " |
• Device Weight: 48 gr. / 1.69 oz. |
• Box Weight: 45 gr./ 1.59 oz |
• Bio Degradable Bag size: 12.2 cm / 4.8 " |
• Bio Degradable Bag Weight: 5 gr / 0.17 oz |
• Total Weight: 98 gr / 3.45 oz |
Note: |
- CAC-1165_SPECIFICATION-SHEET_EN.pdf
- CAC-1165_SPECIFICATION-SHEET_DE.pdf
- CAC-1165_SPECIFICATION-SHEET_ES.pdf
