The CSV-2541 is a USB Type-C® 10Gbps 12-in-1 Triple Displays Docking Station with 2x HDMI™, 1x DisplayPort™, 1x USB Type-C® data port, 3x USB Type-A, RJ45, Card reader ,3.5mm audio port and USB Type-C® charging port, providing an ideal solution for extending the USB Type-C® or Thunderbolt host, especially for those host with a single USB Type-C® port. With bottom bracket design, it can be a stable stand for your laptops. It comes with the 100W charger and the cable included.
• Ergonomic design: Place your laptop on the docking station, plug in USB-C® and enjoy better connectivity, thermal and cable management for your setup.
• 1 GBASE-T GIGABIT ETHERNET: Features a 1Gbps network controller that delivers speeds of 10/100/1000 Mbps; For laptops / devices without an Ethernet.
• 12 PORTS from one USB Type-C®: Expand the connectivity of a USB Type-C® computer by adding Four USB Ports (3x USB Type-A, 1x Type-C®) a Power Delivery 3.0 USB Type-C® Port Max. 100Watt upstream.
• 2 dedicated Card reader slots MicroSD/SD supports SD3.0(UHS-I) with max 104Mbps, card slots work simultaneously.
USB Type C 3.2 Gen1 Triple Display Dynamic PD Charging Dock 100W PD Power charger
USB Gen1 Type-C Triple Display DP Alt mode   Displaylink Dynamic PD Charging Dock with 120 Watt PS
Product Code: CSV-2541
EAN code: 8719214473525
UPC code: 841615103775
• Support DP1.4 Alt mode + DSC.
• Support 8K30Hz per port.
• Support Dual 4K60Hz (if your laptop can output it).
• Support HDR, HDCP 2.3, HDCP1.4, RGB4:4:4 6/8/10/12bit per component (bpc) and YCbCr4:4:4; YCbCr4:2:2; YCbCr4:2:0; 8/10/12 bit bpc.
• Ethernet Support 10/100/1000Mbps bandwidth.
• MicroSD/SD card slots support to transmission data with max 104MBps, allow SD/Micro SD to work simultaneously.
• Support Fast Role Swap of PD 3.0, the connected device will not get disconnected while plugging out PD Adapter.
• The total output of the 4 USB data ports is max. 12W(5V/2.4A).
Supported Resolutions*:
• 8K30Hz, 2x 4K60Hz, 3x(4K60Hz+ 2x 4K30Hz)
• Windows 11
• 1x CSV-2541
• 1x 100W Charger
• 1x RED (Power ONLY) USB Type-C® cable (1m / 3.28 ft)
• 1x USB-C®
• 1x USB-C® PD
• 2x HDMI™
• 1x DisplayPort™
• 1x Ethernet
• 1x MicroSD/SD
• 3x USB-A
• 1x USB-C®
• 1x Headset Jack
• Product size: 30 x 7.4 x 2.2cm / 11.81 × 2.91 × 0.87in
• Box size 36.8 x 10.6 x 7.5 / 14.49 x 4.17 x 2.95in
• Cable length approx.: 19cm / 7.48in
• Connector dimensions:
USB-C® 3.62 x 1.2 x 0.63cm / 1.43 x 0.47 x 0.25in
• Product Weight: 438g / 15.45oz
• Box Weight: 239g / 8.43oz
• Bio Bag Weight: 6g / 0.21oz
• Total Weight: 950g / 33.51oz
*The list of supported resolutions is based on the use of DSC (Display Stream Compression). Make sure your USB-C® port supports DisplayPort ALT mode, which is required to send video through the port. To use the full potential of this device, your setup must support all required standards.
DOCKING STATION
