USB Type-C 4-port 10G Data hub with PD3.0 Charging
The Club 3D CSV-1548 USB Type-C 4-port 10G Data hub with PD3.0 Charging, the compact and comprehensive super fast data hub allows you virtually to connect all data transfer peripherals, including phones/tablets. The hub is compatible with both new Gen2 USB peripherals as well as downwards compatible to legacy USB devices, max data tranfer rate up to 10Gbps(1280MB/s). Extended connection for existing devices, such as a hard drive, SSD, USB flash,mouse, keyboard and/or printer. The Hub also supports Power Delivery 3.0 charging on 1 port.
USB 3.1 Type-C to Type-A Cable 10Gbps PD 60W M/M 1m/3.28ft
Product Name: USB Type-C 4-port 10G Data hub with PD3.0 Charging
Produktserie: Adapter
Artikelcode: CSV-1548
EAN code: 8719214472962
UPC code: 841615103249
• 1x USB Type-C port(with RED lining) supports 10Gbps data transfer and PD3.0 charging max. 100 Watt(20V/5A)
• 3x USB Type-C supports:
USB3.1 Gen2 10 Gbps data transmissions
Support max. 5V/1.5A(7.5Watt) downstream charging, total for these 3 ports 5V/2.4A(12Watt)
• Support PD3.0 Fast Role Swap(FRS)
• Support Plug & Play
• Does NOT support Video
• Compact & Slim design
Applications:
• Connecting USB Type-C peripherals for Data Transfer and charging the connected Host
Note:
• This Hub supports Data and PD3.0 charging ONLY
• Windows 10 or upwards, Mac 13.5.2
• 1X CSV-1548 USB Type-C 10G 4-port hub with PD Charging
• 1x USB Type-C Male
• 4x USB Type-C Female
• Box size: 6 x 18.2 x 3.5 cm / 7.16 x 2.36 x 1.38"
• Device size: 9.5 x 3.8 x 1 cm / 3.74 x 1.5"
• Input Cable length approx.: 18 cm / 7"
• Connector dimensions: 2.9 x 1.2 x 0.5 cm / 1.14 x 0.47 x 0.2"
• Device Weight: 66 gr / 2.33 oz
• Box Weight: 22 gr / 0.78 oz
• Bio Degradable Bag size: 9 x 30 cm / 3.54 x 11.81"
• Bio Degradable Bag Weight:  1 gr./ 0.04 oz
• Total Weight: 89 gr / 3.14 oz
- Club 3D uses environmentally friendly packaging and is printed on recycled paper.
- Club 3D uses Bio-Degradable bags according to the EN/DIN 13432
