DisplayPort™ 1.1 to HDMI™ 1.4 VR ready Passive Adapter
CAC-1056 The Club 3D is a passive HDMI™ signal converter. The DisplayPort™ 1.1a to HDMI™ 1.4a VR Ready Adapter is the easiest solution for connecting your DisplayPort™ 1.1a enabled Game PC / Laptop / Tablet to an HDMI™ 1.4 enabled (U)HD Television, monitor or Projector. The adapter is fully compliant to HDMI™ 1.4a specification allowing for 3Gbps TMDS through-put per channel. The interface in the adapter has three lanes for HDMI data, clock, HPD signal and power, offering a total TMDS throughput of 9Gbps.
Supports up to Full HD Resolution at 120Hz.
The DisplayPort™ 1.1a to HDMI™ 1.4a VR adapter supports (U)HD resolutions of up to 4K UHD 3840 x 2160p @ 30Hz or 1920 x 1080p ~120Hz for a clear, sharp picture. Use the adapter to play games, view video or browse the internet from your DisplayPort™ 1.1 enabled device in (Ultra) high- resolution. Supporting up to 8 channels of audio, the adapter provides High Definition digital audio and video. This is also an ideal solution for use with any VR Device.
Premium High Speed HDMI™ 2.0 UHD Extension Cable 3 m/ 9.84 ft Male/Female
Connector 1: DisplayPort™ 1.1 Male
Connector 2: HDMI™ 1.4 Female
Product Name: Club3D DisplayPort™ 1.1 to HDMI™ 1.4 VR Passive Adapter
Product Series: Accessories
Weight: 40 gr
Cable length: 200 mm
Item Code: CAC-1056
EAN Code: 8719214470159
UPC Code: 841615100248
Club 3D DisplayPort™ 1.1a to HDMI™ 1.4a VR ready Passive Adapter
Compliant to DisplayPort Specification 1.1a
Compliant to HDMI™ 1.4a Specification, data rate up to 3Gbps per TMDS channel. Total throughput 9Gbps
Supports 4K, 2K and 3D video formats over HDMI
Supports DisplayPort all 4 levels of output and all 4 levels of pre-emphasis
Supports full link training and no link training
Repeater for HDCP 1.3
24-bit color and 4:4:4 color sampling
YCbCr 4:4:4 and YCbCr 4:2:2 8/10/12 bpc capability
Supports UHD resolutions up to 3840 x 2160p @ 30Hz and 1920 x 1080p ~120Hz 3D
Supports AMD Eyefinity feature
Compatibility
Operating System Support
Windows 10, 8.1, 7 32 & 64 bit
Apple OS X 10.11, 10.10, 10.9, 10.8
In The Box
Club 3D DisplayPort™ 1.1 to HDMI™ 1.4 VR Passive Adapter
No extra information found.
