USB4 Gen3x2 Type-C Bi-Directional Cable 8K60Hz or 4K120Hz, Data 40Gbps, PD 240W(48V/5A) EPR M/M  3m / 9.84ft
The Club 3D CAC-1579 USB4 Gen3x2 Type-C Bi-Directional Cable 8K60Hz or 4K120Hz, Data 40Gbps, PD 240W(48V/5A) EPR M/M 3m / 9.84ft connects your Notebook, Tablet or Phone with USB4 Type-C output to your favorite existing Peripherals, Accessories and Chargers. It enables Video,Data and Power over a single cable and both ways. Built in signal enhanced Re-timer chips, for enhancing functions over longer distance than a passive USB Type-C cable, together with the E-marker chips on both ends of the cable, provide this cable with support for USB4 Gen3x2 Type-C Bi-Directional Video 8K60Hz or 4K120Hz, Data 40Gbps, PD 240W(48V/5A) EPR M/M over a length of 3m / 9.84ft for Downstream charging or powering your Notebook, Tablet or Smartphone.
USB4 Gen3x2 Type-C Bi-Directional Cable 8K60Hz, Data 40Gbps, PD 240W(48V/5A) EPR M/M 2m / 6.56ft
USB4 Gen3x2 Type-C Bi-Directional USB-IF Certified Cable 8K60Hz, Data 40Gbps, PD 240W(48V/5A) EPR M/M 1m / 3.28ft
USB4 Gen3x2 Type-C Bi-Directional Cable 8K60Hz or 4K120Hz, Data 40Gbps, PD 240W(48V/5A) EPR M/M 3m / 9.84ftt
Product Series: Cables
Product Code: CAC-1579
EAN code: 8719214472856
UPC code: 841615103119
• Video max. 8K60Hz or 4K120Hz
• USB4 Gen3x2 Data 40Gbps
• 240W EPR(Extended Power Range)Charging through a single cable
• Fully Bidirectional
• Built in signal enhanced Re-timer chips for enhancing functions over longer distance than a passive USB Type-C cable
• E-Marker chips for protecting your devices while PD charging
• Data speed up to 40Gbps
• USB Power Delivery, 240 Watt(48V/5A) charging
• Works with Windows 10 or upwards, Mac 13.5.2
Supported resolutions:
• 8K60Hz or 4K120Hz
• Windows 10 or upwards, Mac 13.5.2
• 1X CAC-1579 USB4 Gen3x2 Type-C Bi-Directional Cable 8K60Hz or 4K120Hz, Data 40Gbps, PD 240W(48V/5A) EPR M/M 3m / 9.84ft
• USB Type-C Male
• USB Type-C Male
• Box size: 14.5 x 14.5 x 4.5cm / 5.71 x 5.71 x 1.77"
• Total Cable length approx.: 3m / 9.84ft
• USB Type-C Male Connector dimensions: 3.62 x 1.2 x 0.63 cm / 1.43 x 0.47 x 0.25"
• Bio degradable bag size: 16 x 20 cm / 6.3 x 7.87"
• Cable Weight: 165 gr / 5.85 oz
• Bio degradable bag Weight: 2 gr / 0.07 oz
• Box Weight: 45 gr / 1.59 oz
• Total Weight: 212 gr / 7.48 oz
Warning Safe Usage - Product Only to be used at altitude 2000 meters/6562 feet and below.
Note:
  • No HR images found
