USB C Smart Reader
USB C Smart Reader
USB C Smart Reader
USB C Smart Reader
CSV-1590 The SenseVision USB C Smart Reader is a compact and stylish mobile companion with a brushed aluminum housing. It is fully compatible with Computers, Tablets and Mobile Phones with USB Type C connection and OTG Function. The SenseVision USB Smart Reader also supports Apple U Drive. U-Drive allows you to organize files from iPhone to external accessories.
USB OTG:
USB On-The-Go, often abbreviated to USB OTG or just OTG, is a specification that was introduced in 2001 that allows USB devices, such as Smart Readers or mobile phones, to act as a host, allowing other USB devices, such as USB flash drives, SD Cards, Mice or keyboards, to be attached to them.
Product Name: USB C Smart Reader
Product Series: SenseVision
Item Code: CSV-1590
EAN Code: 8719214470753
UPC Code: 841615100934
• Brushed aluminum housing
• USB C connector
• Ports: 1 x USB A ; 1 x SD; 1 x Micro SD* ; 1 x Micro USB **
• Works on any Computer, Tablet, Mobile Phone with USB C Port and OTG support.
• Can also be used as memory expension for Mobile Phone or Tablet.
• Supports Apple U Drive.
• Transmisison speed up to 5Gbps
* Cannot use SD and Micro SD at the same time
** Cannot use USB C and Micro USB connectors at the same time
All
• USB C Smart Reader
Inputs:
• 1 x USB C Male
Outputs:
• 1 x USB A Female
• 1 x Micro USB Female
• 1 x Secure Digital (SD) Female
• 1 x Micro Secure Digital (SD) Female
• Box size: 75 x 75 x 22 mm
• Adapter size: 38 (L) x 53 (W) x 11 (H)mm
• Weight: 91 gr.
