CAC-1173 The Club 3D CAC-1173 is an active HDMI™ signal converter. The Mini DisplayPort™ 1.2 to HDMI™ 2.0 Cable Active Adapter is the easiest solution for connecting your Mini DisplayPort™ 1.2 enabled Game PC or Laptop to an HDMI™ 2.0 enabled 4K UHD Television, monitor or Projector. The adapter is fully compliant to HDMI™ 2.0 specification allowing for 6Gbps TMDS throughput per channel. The interface in the adapter has three lanes for HDMI data, clock, HPD signal and power, offering a total TMDS throughput of 18Gbps.
Supports up to 4K UHD Resolution at 60Hz. The Mini DisplayPort™ 1.2 to HDMI 2.0 Cable Active Adapter supports (U)HD resolutions of up to 4K UHD 3840x 2160p @ 60Hz for a clear, sharp picture. The support for 60 frames per second provides exceptionally smooth video or gameplay. Use the adapter to play games, view video or browse the internet from your Mini DisplayPort™ 1.2 enabled device in (Ultra) high-resolution. Supporting up to 8 channels of audio, the adapter provides Ultra High Definition digital audio and video. It is the ideal solution for anyone who wants to enjoy 4K UHD/ 60 game-play but lacks a native HDMI™ 2.0 output in their system configuration.The Club 3D is an active HDMI™ signal converter. The Mini DisplayPort™ 1.2 to HDMI™ 2.0 Cable Active Adapter is the easiest solution for connecting your Mini DisplayPort™ 1.2 enabled Game PC or Laptop to an HDMI™ 2.0 enabled 4K UHD Television, monitor or Projector. The adapter is fully compliant to HDMI™ 2.0 specification allowing for 6Gbps TMDS throughput per channel. The interface in the adapter has three lanes for HDMI data, clock, HPD signal and power, offering a total TMDS throughput of 18Gbps.
HDMI to VGA Active Adapter
Maximum resolution:
4K UHD 4096x2160p @60Hz 8Bit and 1920x1080p 3D video @120Hz
Connector 1
Mini DisplayPort™ 1.2 Male
Connector 2
HDMI™ 2.0 Male
Product Name: Mini DisplayPort™ 1.2 Cable to HDMI™ 2.0 UHD 4K60Hz Active Adapter
Product Series: Accessories
Weight: 160gr
Cable length: 3 meters / 9.84 feet
Item Code: CAC-1173
EAN Code: 871921447057
UPC Code: 841615100750
• Supports UHD resolutions up to 4096 x 2160p @ 60Hz, 8Bit BPC
Compatibility
Supports AMD GCN cards, Nvidia® Maxwell cards and Intel® HD 4600 Graphics and newer. Not intended for older architectures (such as Intel Haswell HD Graphics / Nvidia Kepler 5xx/6xx series Graphics)
Operating Systems
Windows 10, 8.1, 7 32 & 64 bit
Apple OS X 10.11, 10.10, 10.9, 10.8
In the Box
No extra information found.
