High Speed HDMI™ 1.4 HD Extension Cable  5M/ 16 ft Male/Female
CAC-1320 This High Speed HDMI™ 1.4 HD Extension Cable 5M/ 16ft Male/Female, enables you to extend your HDMI™ interface of HDTV to any HD device with an HDMI™ output like your Blu-Ray™ Player, Xbox™, PlayStation™, Apple TV™, Streaming Player, HD Cable Box or PC.
Nowadays we have many devices that we want to connect to our TV which makes this product a great solution because it creates flexibility for the placing of such devices. The High Speed HDMI™ 1.4 HD Extension Cable 5M/ 16ft Male/Female Cable is HDMI1.4 compliant and supports HDCP 1.3 to ensure smooth transfer of you Video and Audio signals over the full length of this Extension Cable.
Premium High Speed HDMI™ 2.0 UHD Extension Cable 3 m/ 9.84 ft Male/Female
HDMI™ 1.4 to DisplayPort™ 1.1  Adapter
Connector 1: HDMI™ Type A Male
Connector 2: HDMI™ Type A Female
High Quality High speed HDMI Extension cable with Ethernet, 30AWG
Data transfer rate up to 10.2 Gbps
Supports Dolby® TrueHD and DTS-HD Master Audio™
HDCP compliant
Support resolutions up to 4K at 30Hz / Full HD at 60Hz and 3D
Product is fully plug & play and does not require external power
Weight 320 grams
ITEM code: CAC-1320
EAN code 8719214470135
UPC code 841615100231
No extra information found.
