Premium High Speed HDMI™ 2.0 UHD Extension Cable 3 m/ 9.84 ft Male/Female
CAC-1321 This Premium High Speed HDMI™ 2.0 UHD Extension Cable, enables you to extend your existing HDMI™ cable length by 3 Meters / 9.8 Feet. Nowadays we have many devices that we want to connect to your TV which makes this product a great solution because it creates flexibility for the placing of such devices.
This Premium High Speed HDMI™ 2.0 UHD Extension Cable is fully compliant to HDMI 1.3 / 1.4 and 2.0 standard to ensure smooth transfer of you Video and Audio signals over the full length of this Extension Cable. In combination with this extension cable we advise to use HDMI Male/Male of 28AWG Quality up to 3 Meter, like the Club3D CAC-1310 HDMI™ 2.0 UHD Cable 3M/9.8.
High Speed HDMI™ 1.4 HD Extension Cable  5M/ 16 ft Male/Female
Maximum resolution:
4K UHD 3840x2160p @60Hz and 1920x1080p @ 120Hz and 3D video
Connector 1:
HDMI™ Type A Male
Connector 2:
HDMI™ Type A Female
Product Name: Premium High Speed HDMI™ 2.0 4K60Hz Extension Cable 3m/ 9.8ft Male/Female Product Series: Accessories
Weight: 136 gr
Cable length: 3 meter / 9.8 Feet
Item Code: CAC-1321
EAN Code: 8719214470685
UPC Code: 841615100880
• High Quality Premium High speed HDMI™ 2.0 Extension cable, 30AWG
• Compliant with HDMI™ 1.3 / 1.4 / 2.0 standard
• Data transfer rate up to 18 Gbps
• Support resolutions up to 3840x2160 60Hz / 1920x1200 120Hz 3D *
• Product is fully plug & play and does not require external power
* Functionality is also dependent on the HDMI™ M/M cable used.
In combination with this CAC-1321 extension cable we advise to use HDMI Male/Male cable of 28AWG Quality up to 3 Meter, like the Club3D CAC-1310 HDMI™ 2.0 UHD Cable 3M/9.8Ft.
Operating Systems:
All
Club 3D Premium High Speed HDMI™ 2.0 4K60Hz Extension Cable 3m/9.8ft Male/Female
No extra information found.
