Mini HDMI™ to HDMI™ 2.0 Cable  Male / Male 1 M./ 3.28 Ft.
CAC-1350 The Club 3D Mini HDMI™ to HDMI™ 2.0 Cable delivers an UHD resolution signal for clear, natural pictures and sound. It enables you to connect your Digital Camera/Camcorder, Mini PC, Pico Projector or other device with Mini HDMI™ output to a 4K UHD TV, monitor or projector with HDMI™ input. It fully supports the Premium High Speed HDMI™ with Ethernet specification, ensuring that video up to 4K UHD 3840x2160p at 60Hz is supported, as well as audio and data streams.
The Mini HDMI™ to HDMI™ 2.0 Cables are premium quality making them ideal for use with (Semi) Professional equipment supporting Ultra High Definition Resolutions.
High Speed HDMI™ 1.4 HD Extension Cable  5M/ 16 ft Male/Female
Mini DisplayPort™ 1.2 Cable to HDMI™ 2.0 UHD 4K60Hz Active Adapter Male/Male 3M/ 9.84Ft
DisplayPort™ 1.2 Cable, HBR2 (3 meters)
Maximum resolution:
3840x2160p @60Hz and 1920x1080p 3D video @ 120Hz
Connector 1:
Mini HDMI™ male
Connector 2:
HDMI™ male
Product Name: Mini HDMI™ to HDMI™ 2.0 Cable, 4K 60Hz 1 Meter/3.28 Feet Male/Male
Product Series: Accessories
Weight: 55gr
Cable length: 1 meter/ 3.28 feet
Item Code: CAC-1350
EAN Code: 8719214470661
UPC Code: 841615100842
• Backwards compatible with earlier HDMI™ versions
• Compliant to Premium High Speed HDMI™
• Video Resolutions Support 4K at 60Hz
• Plug & Play and fully Bi-Directional
All
In the Box:
Club 3D Mini HDMI™ to HDMI™ 2.0 Cable, 4K 60Hz 1 Meter/3.28 Feet Male/Male
