USB 3.1 Type C to HDMI™ 2.0  UHD Active Adapter
CAC-1504 The Club 3D is an Active HDMI™ signal converter. The USB 3.1 Type-C to HDMI™ 2.0 UHD Adapter is the easiest solution for connecting your USB 3.1 Type C source device featuring DisplayPort™ Alternate Mode to an HDMI™ 2.0 enabled Monitor, Television or Projector. The HDMI™ adapter is compact and highly portable. Powered by the USB-C port, the adapter requires no external power and is ideal for use with notebooks and Ultrabooks.
The USB 3.1 Type-C to HDMI™ 2.0 adapter supports (U)HD resolutions of up to 4K @ 60Hz for a clear, sharp picture. The support for 60 frames per second provides exceptionally smooth video. Use the adapter to play games, view video or browse the internet from your USB 3.1 Type-C enabled device on a (Ultra) High- resolution monitor or TV. Supporting up to 8 channels of audio, the adapter provides high-definition digital audio and video.
The USB 3.1 Type-C to HDMI™ 2.0 UHD Adapter supports all USB 3.1 Type-C devices with DisplayPort™ ALT mode and operating systems, including Apple OS X, Windows 7, 8.1 and 10 and Google Chrome OS.
USB 3.1 Type C to Gigabit Ethernet Active Adapter
USB Type-C to HDMI™ 1.4  Active Adapter
Maximum resolution:
4K UHD 3840x2160p @60Hz and 1080p 3D video @120Hz
Connector 1
USB Type-C Male
Connector 2
HDMI™ 2.0 Female
Product Name: USB Type-C to HDMI™ 2.0 4K60Hz UHD Active Adapter
Product Series: Accessories
Weight: 56 gr
Cable length: 180 mm
Item Code: CAC-1504
EAN Code: 8719214470050
UPC Code: 841615100149
USB Type-C to HDMI™ 2.0 Active Adapter
Compliant to DisplayPort™ Alternate Mode Specification. Effective (video) bandwidth 17.28Gbps
Compliant to HDMI™ Specification 2.0, data rate up to 6Gbps per TMDS channel. Total throughput 18Gbps
Supports full link training and no link training
Repeater for HDCP 1.3 and HDCP 2.2
24-bit color and 4:4:4 color sampling
Internal YCbCr 4:4:4 /4:2:2 to YCbCr 4:2:0 conversion capability
Supports UHD resolutions up to 3840 x 2160p @ 60Hz and 1080p 3D
Compatible with Thunderbolt 3
Powered by USB Port (no external power needed)
Compatibility
Operating Systems
Microsoft Windows
Google Chrome OS
In the Box
CAC-1504 USB Type-C to HDMI™ 2.0 4K60Hz UHD Active Adapter
