CAC-1517 The Club 3D is a DisplayPort™ signal converter. The USB 3.1 Type C Cable to DisplayPort™ 1.2 UHD Adapter is the easiest solution for connecting your USB 3.1 Type C source device featuring DisplayPort™ Alternate Mode to a DisplayPort™ 1.2 enabled (Ultra) High Definition Monitor, Television or Projector. Powered by the USB Type C port, the adapter requires no external power and is ideal for use with the latest notebooks / MacBook (pro) and Tablets.
Supports up to 4K UHD Resolution at 60Hz and AMD FreeSync.
The USB 3.1 Type C Cable to DisplayPort™ 1.2 UHD Adapter supports (U)HD resolutions up to 4K UHD @ 60Hz for a clear, sharp picture. The support for 60 frames per second provides exceptionally smooth video. Use the adapter to play games, view video or browse the internet from your USB 3.1 Type-C enabled device on a (Ultra) High Resolution monitor or TV. Supporting up to 8 channels of audio, the adapter provides high-definition digital audio and video. Does not support Dual Mode DisplayPort™ (DP++)
The USB 3.1 Type C Cable to DisplayPort™ 1.2 UHD Adapter supports all USB 3.1 Type-C devices with DisplayPort™ ALT mode and operating systems, including Apple OS X, Windows 7, 8.1 and 10 and Google Chrome OS.
Please refer to your device's user manual to confirm the specification and
functionality of the USB-C port.
USB 3.1 Type C to DisplayPort 1.2
USB 3.1 Type C to DVI-D Active Adapter
Maximum resolution:
4K UHD 3840x2160p @ 60Hz and Full HD 1920x1080p 3D video @ 120Hz
Connector 1: USB Type-C Male
Connector 2: DisplayPort™ 1.2 Male
Product Name: USB 3.1 Type C Cable to DisplayPort™ 1.2 UHD Adapter
Product Series: Accessories
Weight: 47 gr
Cable length: 1200 mm
Item Code: CAC-1517
EAN Code: 8719214470616
UPC Code: 841615100798
Reversible USB Type-C connector
Compliant to VESA DisplayPort™ Alt Mode Standard
Supports full link training and no link training
Supports (U)HD resolutions up to 3840 x 2160p @ 60Hz
Supports 3D Video formats up to 1080p @ 120Hz
Compatibel with Thunderbolt 3
Powered by USB Port (no external power needed)
Compatibility
Operating Systems
Microsoft Windows
Google Chrome OS
In the Box
CAC-1517 USB 3.1 Type C Cable to DisplayPort™ 1.2 UHD Adap
No extra information found.
