Mini DisplayPort to DVI-D SL Active Adapter
CAC-1152 The Club 3D CAC-1152 is an Active DVI-D signal converter. The Mini DisplayPort™ to DVI-D Adapter is the easiest solution for connecting your Mini DisplayPort™ enabled Desktop or Laptop to a DVI-D enabled High Definition Television, Monitor or Projector.
The adapter works with AMD, Intel® and Nvidia® graphics solutions and supports a maximum resolution of 1920x1200p @ 60Hz. Simply connect the Mini DisplayPort™ (male) end of the connector to your computer and plug your existing DVI-D cable from the display into the DVI (female) adapter.
Setup requires no software installation. The circuitry built into the adapter seamlessly converts the Mini DisplayPort™ video signal into a DVI Digital video signal. Supports AMD Eyefinity and other Multi Monitor configurations. Please note that this adapter is for digital signals only and will not fit analog DVI-I ports.
Mini DisplayPort 1.2 to HDMI 2.0 Active Adapter
Connector 2: DVI-D Active Single Link Female
Club 3D graphics cards with Mini DisplayPort™ connector and any DVI-D (Single Link) & DVI-D (Dual Link) compatible screen
• Club 3D Mini DisplayPort™ to DVI-D SL Active Adapter
• Compliant to DisplayPort™ 1.1 Specification
• Compliant to DVI-D specification
• Supports resolutions up to WUXGA 1920x1200p @ 60Hz
• Supports AMD Eyefinity
• No external power needed
• Supports AMD, Nvidia® and Intel® graphics solutions
Please note that this adapter cable is for digital signals only and will not fit an analog DVI-I connector
No extra information found.
