MiniDisplayPort to DisplayPort 1.4 HBR3 Cable M/M 2m/6.56feet
CAC-1115 The Club 3D Mini DisplayPort™ to DisplayPort™14 HBR3 cable enables the connection of your Mini DisplayPort™ supported source device to a monitor or other DisplayPort™ supported device. It features a locking DisplayPort connector providing a secure, dependable connection. Simply press the built-in one- touch latch button to unlock the connector.
Mini HDMI to HDMI 2.0 Cable M/M 1m/3.28ft
MiniDisplayPort 1.4 HBR3 Cable M/M 2m/6.56 Ft.
Maximum resolution:
- 8K @ 60Hz
- 4K at 120 Hz
Without compression:
(DSC) DisplayPort 1.4 can support up to: - 5K @ 60Hz
Product Name:Mini DisplayPort™ to DisplayPort™ 1.4 HBR3 8K60Hz Cable Male / Male 2 mtr. / 6.56 Ft.
Product Series: Accessories
Weight: 93 gr
Item Code: CAC-1115
EAN Code: 8719214470630
UPC Code: 841615100811
• Support resolutions up to 8K @ 60Hz
• Bi-Directional
Operating System Support:
All
