DisplayPort to DVI-D SL Active Adapter
CAC-1052 The Club 3D is an Active DVI-D signal converter. The DisplayPort™ to DVI-D Adapter is the easiest solution for connecting your DisplayPort™ enabled Desktop or Laptop to a DVI-D enabled High Definition Television, Monitor or Projector.
The adapter works with AMD, Intel® and Nvidia® graphics solutions and supports a maximum resolution of 1920x1200p @ 60Hz. Simply connect the DisplayPort™ (male) end of the connector to your computer and plug your existing DVI-D cable from the display into the DVI (female) adapter.
Setup requires no software installation. The circuitry built into the adapter seamlessly converts the DisplayPort™ video signal into a DVI Digital video signal. Supports AMD Eyefinity and other Multi Monitor configurations. Please note that this adapter is for digital signals only and will not fit analog DVI-I ports.
Connector 2: DVI Active Single Link Female
Club 3D graphics cards with DisplayPort connector or any DisplayPort™ compatible device. Compatible with AMD Eyefinity™.
Please note that this adapter is for digital signals only and will not fit a digital DVI-I port
No extra information found.
