DVI to VGA Passive Adapter
CAA-DMA>CFA The Club 3D DVI to VGA Passive Adapter enables the connection of your DVI-I or DVI-A supported Gaming PC, workstation or laptop to a legacy VGA supported Analog Television, Monitor or Projector. Supports resolutions up to WUXGA 1920x1200p @60Hz. Supports 1080p Full HD video playback.
Compatible with AMD, Nvidia and Intel graphics solutions.
DisplayPort™ to VGA Active Adapter
USB Type-C to HDMI™ 1.4  Active Adapter
High Speed HDMI™ 1.4 HD Extension Cable  5M/ 16 ft Male/Female
Connector 1: DVI Male (12+5 wired)
Connector 2: VGA Female
Product Name: DVI to VGA adapter
Product Series: Accessoiries
Item Code: CAA-DMA>CFA
EAN Code: 8717249407881
Length: 40 mm
DVI: 1x
VGA: 1x
Max. Res. digital: 1920 x 1200
Max. Res. analog: 2048 x 1536
HDTV: YES
HDCP: YES
Bundle
Club 3D DVI-I or DVI-A to VGA adapter
Club 3D graphics card with DVI-I or DVI-A connector and any VGA compatible device
AMD EYEFINITY
