HDMI 1.4 to VGA Adapter
CAC-1301 This Club3D Adapter is an active HDMI™ 1.4 to VGA signal converter. It ac­cepts HDMI™ input from HDMI™ 1.4 enabled Desktop or Laptop and converts to a legacy analog VGA output allowing the use of analog VGA Televisions, Monitors and Projectors. The adapter offers hassle free plug and play func­tionality and is powered by the HDMI™output.
The HDMI™ 1.4 interface in the adapter consists of two main lanes for HDMI™ data, AUX channel, HPD signal and power. The VGA output is compliant to VSIS standard and supports up to WUXGA RB timings.
The adapter works with AMD, Nvidia and Intel Graphic Solutions and sup­ports AMD Eyefinity™.
HDMI to VGA Active Adapter
High Speed HDMI 1.4 HD Extension Cable M/F 5m/16ft
HDMI™ 1.4 to VGA Active Adapter
Product Series:
Accessories
Itemcode
CAC-1301
EAN code: 8719214470654
UPC code: 841615100835
• HDMI™ 1.4 Male
• VGA Female
• Supports HDMI™ 1.4 input specs
• Triple 8-bit DAC (Digital-to-Analog Converter) with clock up to 210-MHz
• Powered by the HDMI™ output
• Compliant with the VESA VSIS
• Real-time Hot plug detection
• HDCP support is not possibble with Analog / VGA Displays
• DisplayPort 1.1a  compliant receiver offering 5.4Gbps bandwidth over 2 lanes
No extra information found.
