![](banner/600x600/13_1.jpg)
CAC-2170 - The Club 3Dis an active HDMI™ 2.0 signal converter. The Mini DisplayPort™ 1.2 to HDMI™ 2.0 UHD Active Adapter is the easiest solution for connecting your Mini DisplayPort™ 1.2 Game PC or Laptop to an HDMI™ enabled 4K UHD Television, monitor or Projector. The adapter is compliant to HDMI™2.0 specification allowing for 6Gbps TMD Sthroughput per channel. The interface in the adapter has three lanes for HDMI™ data, clock, HPD signal and power, offering a total TMDS throughput of 18Gbps.
The Mini DisplayPort™ 1.2 to HDMI™ 2.0 UHD Active Adapter supports UHD resolutions of up to 4K UHD 4096x 2160p @ 60Hz for a clear, sharp picture. The support for 60 frames per second provides exceptionally smooth video or gameplay. Use the adapter to play games, view video or browse the internet from your MiniDisplayPort™ 1.2 enabled device in Ultra High Resolution. Supporting up to 8 channels of audio, the adapter provides Ultra High Definition digital audio and video. It is the ideal solution for anyone who wants to enjoy 4K UHD/ 60 gameplay but lacks a native HDMI™ 2.0 output in their system configuration.
Model: |
Product Name: Mini DisplayPort™ 1.2 to HDMI™ 2.0 UHD Active Adapter |
Product Series: Adapters |
Itemcode: CAC-2170 |
EAN code: 8719214470982 |
UPC code: 841615101177 |
• Compliant to DisplayPort™ Specification 1.2 for 1.62Gbps,2.7Gbps and 5.4Gbps per lane. Effective (video) bandwidth 17.28Gbps |
• Compliant to HDMI™ 2.0 Specification, data rate up to 6Gbps per channel total throughput 18Gbps |
• Supports full link training and no link training |
• Repeater for HDCP 1.3 and HDCP 2.2 |
• Supports 24-bit color and 4:4:4 color sampling |
• Internal YCbCr 4:4:4 /4:2:2 to YCbCr 4:2:0 conversion capability |
• Supports UHD resolutions up to 4096 x 2160p @ 60Hz and 1080p 3D |
• Supports Nvidia® Maxwell cards and Intel® HD 5XXX series and newer. Not intended for older architectures. |
Windows 10, 8.1 |
Apple OS X |
Mini DisplayPort™ 1.2 Male |
HDMI™ 2.0 Female |
• Packaging size: 24 x 16 x 1.5cm / 9.45 x 6.3 x 0.59" |
• Poly Bag Weight: 8 gr. |
• Product LxWxD: 200x45x15 mm |
• Product Weight: 25 gr. |
• Weight product with Poly Bag: 33gr. |
• Made in China |
Club 3D Mini DisplayPort™ 1.2 to HDMI™ 2.0 UHD Active Adapter |
-HIGH DEFINITION AND MORE
POSSIBLE RESOLUTIONS
