Displayport to VGA Active Adapter
CAC-2003 - The Club 3D is an active DisplayPort™ to VGA signal converter. It enables you to connect your analog VGA Televisions, Monitors or Projectors to your Desktop or Laptop with DisplayPort™ output.
The adapter offers hassle free plug and play functionality, so no Driver installation needed and it is powered by the DisplayPort™ output.
The DisplayPort™ interface in the adapter consists of two main lanes for DP data, AUX channel, HPD signal and power. The VGA output is compliant to VSIS standard and supports up to WUXGA RB timings.
The adapter works with AMD, Nvidia and Intel Graphic Solutions.
DisplayPort 1.4 HBR3 Cable M/M 2m/6.56ft.
DisplayPort 1.4 to DisplayPort 1.4 M/M 1m/3.28ft
Product Name: DisplayPort™ to VGA Active Adapter
Product Series: Adapters
Itemcode: CAC-2003
EAN code: 8719214470951
UPC code: 841615101146
• Automatic sink detection
• Microsoft Windows 10, 8.1
• Apple OS X
DisplayPort™ Male
VGA Female
• Poly Bag: 240 x 160 mm.
• Poly Bag Weight: 9 gr
• Product LxWxD: 250 x 38 x 12 mm
• Product Weight: 42 gr.
• Weight product with Poly Bag: 51 gr.
• Club 3D CAC-2003 DisplayPort™ to VGA Active Adapter
