HDMI 2.0 4K60Hz UHD 360 Degree Rotary cable 2m/6.56ft
CAC-1360 - The Club 3D HDMI™ 2.0 4K60Hz UHD 360° Rotary Cable can be twisted or turned to virtually any position. The Rotator connectors feature a center ball joint design that enables a 360 degree rotation and bending. The CAC-1360 design ensures signal integrity in any position and its flexibility makes it ideal for installations in tight/narrow spaces where standard connectors are hard to fit without having to bend the cable at sharp angles.
It fully supports the HDMI™ 2.0 with Ethernet specification, ensuring that video up to 4K UHD, 4096x2160p at 60Hz is supported, as well as audio and data streams.
Model: |
Product Name: HDMI™ 2.0 4K60Hz UHD 360° Rotary Cable 2m/6.56ft Male/Male |
Product Series: Cables |
Itemcode: CAC-1360 |
EAN code: 8719214471019 |
UPC code: 841615101207 |
• Compliant to HDMI™ with Ethernet specification version 2.0 |
• Features 360 Degree Rotating Connectors |
• Supports UHD TV resolutions up to 4096x2160p @ 60Hz |
• Supports 3D resolutions up to 1080p Full HD @ 120Hz |
• Supports up to 32 audio channels for the total audio experience |
• Supports up to 1536 KHz audio sample frequency for the highest audio fidelity |
All |
HDMI™ 2.0 Male |
HDMI™ 2.0 Male |
• Packing size: 145 x 145 x 45 mm |
• Packing Weight: 51 gr. |
• Product Weight: 111 gr. |
• Product size LxBxD: 2000 x 21 x 10 mm |
• Product plus Packing weight: 162 gr. |
• Made in China |
Club 3D HDMI™ 2.0 4K60Hz UHD 360° Rotary Cable 2m/6.56ft. |
