CAC-1310 The Club 3D HDMI™ 2.0 High Speed 4K UHD cable enables the connection of your HDMI™ 2.0 supported Gaming PC or Laptop to an (Ultra) High Definition Monitor or other HDMI™ 2.0 supported device. It fully supports the ‘HDMI High Speed with Ethernet’ specification, ensuring that video up to 4K UHD 3840x2160p at 60Hz is supported, as well as audio and data streams. The cable combines the unmatched signal quality and convenience of HDMI™ connectivity with the power and flexibility of home entertainment networking. It includes a dedicated data channel into the HDMI™ link, enabling high speed networking at up to 100 Mbps. It is the ideal solution for the ultimate future proof HDMI™ 4K UHD Gaming and Viewing experience.
Maximum resolution:
4K UHD 3840x2160p @60Hz and 1920x1080p 3D video @ 120Hz
Connector 1:
HDMI™ Type A Gold plated male
Connector 2:
Compliant to HDMI™ High Speed with Ethernet specification
Premium quality braided cable with metal connector head
Gold plated connectors for maximum conductivity
Supports HDMI™ 2.0 specification
Backwards compatible to support HDMI™ 1.4 specification
Supports (U)HDTV resolutions up to 3840x2160 @ 60Hz
Supports 3D resolutions up to 1080p Full HD @ 120Hz
Total Data throughput of 18Gbps, three lanes, 6Gbps per lane
Supports AMD, Nvidia and Intel graphics solutions
Weight 200 grams
ITEM code: CAC-1310
EAN Code: 8719214470449
UPC Code: 841615100569
POSSIBLE RESOLUTIONS
