USB Type-C to Ethernet + USB 3.0 + USB Type-C Charging Mini Dock
CSV-1530 The SenseVision USB Type-C to Ethernet + USB 3.0 + USB Type-C Charging Mini Dock is a portable and convenient tool for your USB Type-C enabled Laptop or Ultrabook. The integrated RJ45 Gigabit Ethernet port provides a fast and stable wired network connection in places where a Wireless signal is too weak or unsafe. The SuperSpeed USB 3.0 Type-A port connects your USB Sticks, Peripherals and HDD’s. Use the USB Type-C Power Delivery input to charge your device with up to 60Watts at the same time. Supports Microsoft Windows® and Apple OS X.
USB 3.0 Hub 4-Port with Power Adapter
MiniDisplayPort 1.4 HBR3 Cable M/M 2m/6.56 Ft.
Product Name: USB Type C to Ethernet + USB 3.0 + USB Type C Charging Mini Docking Station
Product Series: SenseVision
Weight: 51 gr
Connector length: 55mm
Item Code: CSV-1530
EAN Code: 8719214470470
UPC Code: 841615100606
USB 3.0 Type C male x 1
RJ45 Ethernet female x 1
USB 3.0 Type-A female x1 (for Data)
USB 3.0 Type-C female x1 (for Charging)
SenseVision USB Type C to Ethernet + USB 3.0 + USB Type C Charging Mini Docking Station
• Innovative Portable Design
• Folding USB Type C Connector
• Supports Gigabit Ethernet RJ45 (10/ 100/ 1000Mbps)
• Fully compliant with IEEE802.3 and IEEE802.3u
• 1x USB 3.0 Type-A port for Data (max 5Gbps)
• 1x USB Type C for Charging PD (5V/ 1.5A, 20V/3A)
GPU: AMD, Intel or Nvidia
RAM: 1GB or higher
USB port: Type C 2.0/3.0
30MB of available disk space
Supported Operating Systems:
Windows 7 (32 & 64 Bit)
Windows 8.1 (32 & 64 Bit)
Windows 10 (32 & 64 Bit)
And under Beta:
Android 5.X
Ubuntu Linux
DOCKING STATION
THUNDERBOLT TECHNOLOGY
