Displayport™ to VGA Active Adapter
CAC-1003 The Club 3D is an active DisplayPort™ to VGA signal converter. It accepts DisplayPort™ input from a DisplayPort™ enabled Desktop or Laptop and converts to a legacy analog VGA output allowing the use of analog VGA televisions, monitors and projectors. The adapter offers hassle free plug and play functionality and is powered by the DP output.
The DisplayPort™ interface in the adapter consists of two main lanes for DP data, AUX channel, HPD signal and power. The VGA output is compliant to VSIS standard and supports up to WUXGA RB timings.
The adapter works with AMD, Nvidia and Intel Graphic Solutions.
DisplayPort™ 1.2 Cable to HDMI™ 2.0 UHD 4K60Hz Active Adapter Male/Male 3M/ 9.84Ft
DisplayPort™ 1.2 Cable, HBR2 (3 meters)
DisplayPort™ to DVI-D SL Active Adapter
Connector 2: VGA Female
Product Name: DisplayPort™ to VGA Active Adapter
Product Series: Accessories
Weight: 56 gr
Cable length: 180 mm
Item Code: CAC-1003
EAN Code: 8719214470784
UPC Code: 841615100972
• Automatic sink detection
Compatibility
Operating Systems
Windows
In the Box
Club 3D CAC-1003 DisplayPort to VGA Active Adapter
AMD EYEFINITY
