DisplayPort 1.4 to HDMI 2.0a HDR
CAC-1080 - The Club3D CAC-1080 is a DisplayPort™ 1.4 to HDMI™ 2.0a active signal converter. It features support for HDR Video quality for deep color media content playback. The DisplayPort™ receiver supports up to 5,4 Gbps per lane over 4 lanes. The HDMI™ output is fully compliant to HDMI™ specification version 2.0a. The CAC-1080 is downwards compatible to earlier Displayport™ and HDMI™ versions, but this can influence the functionality and/or supported features such as HDR.
Resolution Support
The CAC-1080 supports UHD resolutions up to 4096 x 2160p at 60Hz.
Color Formats
It supports RGB/YCbCr video color formats with a color depth of 16bpc (or 48 bits per pixel) as long as it fits within the DisplayPort™ and HDMI™ link bandwidth. The CAC-1080 also supports pixel encoding conversion from RGB or YCbCr 4:4:4 to YCbCr 4:2:0 and YCbCr 4:2:0 pass-trough function. In addition HDR with deep color up to 12Bpc at 4K 60Hz is supported through the conversion of RGB/YCbCr 4:4:4 over DP link to YCbCr 4:2:0 on the HDMI™ output with a horizontal expansion to CEA timings.
Note: For HDR to function, the source system needs to support DisplayPort™ 1.4 and the screen needs to have support for HDR and/or HDMI™ 2.0a
HDMI 2.0 4K60Hz UHD cable 5m/16.4ft
Product Name: DisplayPort™ 1.4 to HDMI™ 2.0a HDR Active Adapter
Product Series: Adapters
Itemcode: CAC-1080
EAN code: 8719214470852
UPC code: 841615101047
• Video Stream Handling
• Audio Stream Handling
• HDCP Support
• HDMI™ transmitter
- Compliant to HDMI™ specifications version 2.0a
- 4K 30Hz RGB/YCbCr 4:4:4, up to 16bpc
Windows 10, 8.1
DisplayPort™ 1.4 male
HDMI™ 2.0a female
• Boxsize: 182 x 60 x 35mm.
• Cable: 184 x 20 x 11 mm.
• Product Weight: 32 gr.
Club 3D DisplayPort™ 1.4 to HDMI™ 2.0a HDR Active Adapter
POSSIBLE RESOLUTIONS
