Tabelle A
 Display resolutions' chart
HD 1280x720 QHD+ 3200x1800 6K 6144x3160 16K 15360x8640
Full HD 1920x1080 UHD / 4K 3840x2160 8K 7680x4320 - -
QHD / 2K 2048x1080 4K 4096x2160 10K 10240x4320 - -
WQHD 2560x1440 5K 5120x2880 12K 12288x6480 - -
Note: The aspect ratio and pixel ratio between monitors and TV may vary. There are also several differences per brand. Consult the specifications of your supplier for this.
 Possible resolutions for Video Splitters
VIDEO SPLITTER ITEM CODE MAXIMUM SUPPORTED RESOLUTIONS *
x 2 SCREENS x 3 SCREENS x 4 SCREENS
DISPLAYPORT MST CSV-5200 2* 2560x1440 @ 60Hz
or
2* 3840x2160 @ 30Hz
CSV-6200
CSV-6200H
CSV-3203
CSV-6400 2* 2560x1440 @ 60Hz
or
2* 3840x2160 @ 30Hz
3* 1920x1080 @ 60Hz 4* 1920x1080 @ 60Hz
CSV-7300 2* 3840x2160 @ 60Hz
3* 3840x2160 @ 60Hz
CSV-1545 3840x2160 (Ultra HD 4K) @60hz - -
CSV-1546 3840x2160 (Ultra HD 4K) @30hz - -
CSV-1550 2* 3840x2160 60Hz (24bpp) 3 *3840x2160 60Hz
CSV-1556 3840x2160 (Ultra HD 4K) @ 60hz - -
HDMI CSV-1370 4096x2160 @ 60Hz (input) 4096x2160 @ 60Hz (input) 4096x2160 @ 60Hz (input)
CSV-1380 4096x2160 @ 60Hz 4096x2160 @ 60Hz
mirror
4096x2160 @ 60Hz
mirror
CSV-13817680x4320 @ 60Hz
mirror
7680x4320 @ 60Hz mirror
THUNDERBOLT 3 CSV-1577 4096x2160 @ 60Hz - -
CSV-1574 3840x2160 @ 60Hz - -
USB TYPE A CSV-1477 4096x2160 @ 60Hz - -
CSV-1474 3840*2160 @ 60Hz
* The maximum supported resolutions are also dependent on the capacity of the Graphics inside the source system.
 Possible resolutions for Docking Stations
DOCKING ITEM CODE MAXIMUM SUPPORTED RESOLUTIONS *
X 1 SCREEN X 2 SCREENS X 3 SCREENS
USB TYPE C CSV-1560 3840x2160 @ 30Hz
1920x1200 @ 60Hz
CSV-1460 5120x2880 @ 60Hz
3840x2160 @ 60Hz
CSV-1562 4K 60Hz via DP or HDMI 4K 60Hz via DP or HDMI 4K 30Hz
CSV-1564
CSV-1564W65
CSV-1564W100
HDMI™ 4K 30Hz
DP™ 4K 30Hz
VGA 1920x1200 @ 60Hz
HDMI™ 1920x1080 @ 60Hz
DP™ 1920x1080 @ 60Hz
VGA 1920x1080 @ 60Hz
HDMI™ 1280x720 @ 60Hz
DP™ 1280x720 @ 60Hz
VGA 1280x720 @ 60Hz
CSV-1591 4K 60Hz via DP or HDMI - -
CSV-1592 4K60Hz via DP or HDMI - -
CSV-1593 4K60Hz 4K/30Hz under MST mode
(Windows™ System)
4K/60Hz under SST mode
(Mac™ System ONLY)
USB TYPE A CSV-3103D 3840x2160 @ 30Hz
2048x1152 @ 60Hz
CSV-3104D 3840x2160 @ 30Hz
2048x1152 @ 60Hz
CSV-3242HD 2048x1152 @ 60Hz
2048x1152 @ 60Hz
CSV-3242HDA 2048x1152 @ 60Hz
2048x1152 @ 60Hz
3840x2160 @ 60Hz
Mögliche Auflösungen von HDMI™
Possible resolutions of HDMI™
DescriptionResolutionRefresh Rate (Hz)Data RateHDMI Version / Maximum Data Rate*
1.0 - 1.11.2 - 1.2a1.3 - 1.4b2.0 -2.0b2.1
3.96
Gbit/s[b]
3.96
Gbit/s[b]
8.16
Gbit/s[b]
14.4
Gbit/s[b]
42.6
Gbit/s[b]
720p1280 x 72024592,42 Mbit/sYESYESYESYESYES
30740,52 Mbit/sYESYESYESYESYES
601,49 Mbit/sYESYESYESYESYES
1203,08 Gbit/sNOYESYESYESYES
1080p1920 × 1080301,63 Gbit/sYESYESYESYESYES
603,29 Gbit/sYESYESYESYESYES
1206,78 Gbit/sNONOYESYESYES
1448,15 Gbit/sNONOYESYESYES
24014,40 Gbit/sNONONOYESYES
1440p2560 × 1440302,86 Gbit/sNOYESYESYESYES
605,79 Gbit/sNONOYESYESYES
757,29 Gbit/sNONOYESYESYES
12011,92 Gbit/sNONONOYESYES
14414,40 Gbit/sNONONOYESYES
16516,76 Gbit/sNONONONOYES
24025,32 Gbit/sNONONONOYES
4K3840 × 2160306,36 Gbit/sNONOYESYESYES
6012,90 Gbit/sNONONOYESYES
7516,24 Gbit/sNONONONOYES
12025,90 Gbit/sNONONONOYES
14432,24 Gbit/sNONONONOYES
24056,40 Gbit/sNONONONOYES DSC SUPPORT**
5K5120 × 28803011,25 Gbit/sNONONOYESYES
6022,81 Gbit/sNONONONOYES
12046,96 Gbit/sNONONONOYES DSC SUPPORT**
8K7680 × 43203025,18 Gbit/sNONONONOYES
6051,07 Gbit/sNONONONOYES DSC SUPPORT**
120105,11 Gbit/sNONONONOYES DSC SUPPORT**
*Maximum Data Rate means 8b/10b overhead substracted.
**DSC - Display Stream Compression. VESA , the Video Electronics Standard Association published a new standard in 2014 that uses visually lossless image compression to increase the amount of data carried by a display interface data rate , thus saving power.
Mögliche Auflösungen von DisplayPort™
Possible resolutions of DisplayPort™
Description Resolution Refresh Rate (Hz) Data Rate DisplayPort Version / Maximum Data Rate*
1.0 -1.1a 1.2 -1.2a 1.3 1.4
8.64
Gbit/s[b]
17.28
Gbit/s[b]
25.92
Gbit/s[b]
25.92
Gbit/s[b]
720p 1280 x 720 24 592,42 Mbit/s YES YES YES YES
30 740,52 Mbit/s YES YES YES YES
60 1,49 Mbit/s YES YES YES YES
120 3,08 Gbit/s YES YES YES YES
1080p 1920 × 1080 30 1,63 Gbit/s YES YES YES YES
60 3,29 Gbit/s YES YES YES YES
120 6,78 Gbit/s YES YES YES YES
144 8,15 Gbit/s YES YES YES YES
240 14,40 Gbit/s NO YES YES YES
1440p 2560 × 1440 30 2,86 Gbit/s YES YES YES YES
60 5,79 Gbit/s YES YES YES YES
75 7,29 Gbit/s YES YES YES YES
120 11,92 Gbit/s NO YES YES YES
144 14,40 Gbit/s NO YES YES YES
165 16,76 Gbit/s NO YES YES YES
240 25,32 Gbit/s NO NO YES YES
4K 3840 × 2160 30 6,36 Gbit/s YES YES YES YES
60 12,90 Gbit/s NO YES YES YES
75 16,24 Gbit/s NO YES YES YES
120 25,90 Gbit/s NO NO YES YES
144 32,24 Gbit/s NO NO NO YES DSC SUPPORT**
240 56,40 Gbit/s NO NO NO YES DSC SUPPORT**
5K 5120 × 2880 30 11,25 Gbit/s NO YES YES YES
60 22,81 Gbit/s NO NO YES YES
120 46,96 Gbit/s NO NO NO YES DSC SUPPORT**
8K 7680 × 4320 30 25,18 Gbit/s NO NO YES YES
60 51,07 Gbit/s NO NO NO YES DSC SUPPORT**
120 105,11 Gbit/s NO NO NO NO
**Maximum Data Rate means 8b/10b overhead substracted.
Mögliche Auflösungen von DVI
Possible resolutions of DVI
Description Resolution Refresh Rate (Hz) Data Rate DVI / Maximum Data Rate*
Single Link Dual Link
3.96
Gbit/s[b]
7.92
Gbit/s[b]
120 3,08 Gbit/s NO YES
120 6,78 Gbit/s NO YES
144 8,15 Gbit/s NO NO
240 14,40 Gbit/s NO NO
1440p 2560 × 1440 30 2,86 Gbit/s NO YES
60 5,79 Gbit/s NO YES
75 7,29 Gbit/s NO YES
120 11,92 Gbit/s NO NO
144 14,40 Gbit/s NO NO
165 16,76 Gbit/s NO NO
4K 3840 × 2160 30 6,36 Gbit/s NO YES
60 12,90 Gbit/s NO NO
75 16,24 Gbit/s NO NO
5K 5120 × 2880 30 11,25 Gbit/s NO NO
