USB 3.2 Gen1 Active Repeater Cable 5m/ 16.40ft M/F 28 AWG
With this Club3D USB 3.2 Gen1 Active Repeater Cable CAC-1401, you can go far beyond the standard USB Cable length limitation of 3 meters, without loss of Data Transfer Speed. The USB 3.2 Gen1 Active Repeater Cables are fully Plug & Play and do not require any driver installation. Just connect your external USB device like External HDD/NAS/Digital Camera or External USB Graphics to your system with the CAC-1401 and have flexibility of the increased 5 meters of extra cable length. Also for a VR experience at the sofa away from the notebook or PC this cable provides you with the freedom of movement.
The CAC-1401 supports data transfer rates up to 5Gbps over the full length of the cable.
Please use one of our Club 3D (Extension) cables to connect from the Adapter Cable to your devices: In case you need assistance to choose the correct cable, please visit our website www.club-3d.com or feel free to mail us at [email protected] and it will be our pleasure to assist you.
Product Name: USB 3.2 Gen1 Active Repeater Cable 5m/ 16.40ft M/F 28 AW |
Product Series: Cable |
Product Code: CAC-1401 |
UPC code: 854365005299 |
EAN code: 8717249401209 |
• USB 3.2 Gen1 SuperSpeed specification |
• Supports data transfer speeds up to 5 Gbps |
• Plug and play functionality |
• No drivers required |
• Cable: 28AWG, OD: 7mm |
• Windows™ and Mac OSX™ compatible |
OS Support: All |
In the box: CAC-1401 Active Repeater Cable 5 m/ 16.40 ft Male/Female |
Available Interfaces: |
Input: 1x USB 3.2 Gen1 Male |
Output: USB 3.2 Gen1 Female |
• Box size 17.5 x 17.5 x 6 cm / 6.89 x 6.89 x 2.36 inch |
• Cable Weight: 320 gr/ 11.3 oz |
• Total Cable length 5m / 16.4 ft |
• Connector dimensions: |
- USB Type A Male 4 x 0.7 x 1.5 cm / 1.57 x 0.28 x 0.6 inch |
- USB Type A Female 7.5 x 1.3 x 2.2 cm / 2.96 x 0.51 x 0.87 inch |
• Box Weight 85gr / 3 oz |
• Total Weight: 405 gr / 14.3oz |
- SPECIFICATION SHEET_CAC-1401_EN.pdf
- SPECIFICATION SHEET_CAC-1401_DE.pdf
- SPECIFICATION SHEET_CAC-1401_ES.pdf
