USB Type-C to Triple DisplayPort™ MST Hub 4K60Hz
The CSV-1553 is a MST hub to DisplayPort™. This USB-C MST hub is designed to cater for your most versatile connectivity demands, such as Mobile Phone, Tablet, laptop, etc. with a USB Type-C output which supports DP™ Alt-Mode as Host to 3 DisplayPort ports with Ultra High Definition support. It supports DP2.1 AltMode and will allow you to output one Display with max capability of a single 8K30Hz or dual displays of 8K30Hz + 4K144Hz support or triple displays of 4K60Hz Each. It supports on all DisplayPort Alternate Mode supported USB Type-C or Thunderbolt4 compatible devices.
Give your Phone, Ultrabook more displays. Phones, Ultrabooks and notebooks are increasingly becoming more powerful and smaller in the physical form factor. With a single USB Type-C DisplayPort Supported port available you can now drive up to 3x Displayport™ screen simultaneously . All it needs is a free USB Type-C with DP™ Alt-Mode on your Phone, Laptop or Ultrabook to connect to the MST hub and will provide you with unparalleled connection options for Triple 4K60Hz displays. The setup is easy and simple to do, provided your system supports this function.
Product Name: USB Type-C to Triple DisplayPort™ MST Hub 4K60Hz |
Product Code: CSV-1553 |
EAN-Code: 8719214473174 |
UPC-Code: 841615103423 |
• Support USB Type-C Input and 3 DisplayPort Outputs |
• Support DP2.1 AlternateMode USB Type-C Devices |
• Support SST mode at MAC OS® |
• Support MST mode at Windows® |
• Support Max 8K30Hz for One video Output |
•Support to output Dual Displays 8K30Hz + 4K144Hz |
•Support Triple 4K60Hz |
•Support HDCP 2.2 and downwards |
• Support HDR |
• Support DP++ |
Supported resolutions: |
• Windows System / Mac OS System |
Single Port Connected 8K/30Hz / 4K/144Hz |
Dual Port Connected |
(The host screen on) 8K/30Hz+4K/144Hz / 4K/144Hz*2 |
Triple Port Connected |
(The host screen on) 4K/60Hz *3 / 4K144Hz*3 |
*Please note output support on MacOS system is limited to SST |
• Works with Windows, Mac OS, Chrome OS |
Available Interfaces: |
• USB Type-C port with DP™ Alt-Mode support Male |
• DisplayPort x 3 Female |
• CSV-1553, USB Type-C to Triple DisplayPort™ MST Hub 4K60Hz |
• Box size: 6 x 18 x 3.5 cm / 7.08 x 2.36 x 1.38" |
• Total length Device: 28.55 cm/ 11.24" |
• Box Weight: 45 gr / 1.58 oz |
• Device Weight: 53 gr / 1.87 oz |
• Biodegradable Bag Weight: 5 gr / 0.17 oz |
• Total Weight: 103 gr / 3.63 |
Note: |
• The above is the supported features - the Host and display must support them too. |
Please use one of our Extension/Adapter cables to connect to your devices: In case you need assistance to choose the correct cable, feel free to mail us at [email protected] and it will be our pleasure to assist you. |
- CSV-1553_SPECIFICATION-SHEET_EN.pdf
- CSV-1553_SPECIFICATION-SHEET_DE.pdf
- CSV-1553_SPECIFICATION-SHEET_ES.pdf
