CAC-2312 - The Club 3D HDMI™ 2.0 4K60Hz UHD Cable enables the connection of your HDMI™ supported Gaming PC or Laptop to an (Ultra) High Definition Monitor or other HDMI™ supported device.
It fully supports the HDMI™ with Ethernet specification, ensuring that video up to 4K UHD, 4096x2160p at 60Hz is supported, as well as HDR, audio and data streams.
The 5 meter/16.40 feet cable combines the unmatched signal quality and convenience of HDMI™ connectivity with the power and flexibility of home entertainment networking.
It includes a dedicated data channel into the HDMI™ link, enabling high speed networking at up to 100 Mbps. It is the ideal solution for the ultimate future proof HDMI™ 4K UHD Gaming and Viewing experience.
Model: |
Product Name: HDMI™ 2.0 4K60Hz UHD Cable 5m/16.40ft Male/Male |
Product Series: Cables |
Itemcode: CAC-2312 |
EAN code: 8719214470920 |
UPC code: 841615101115 |
• Compliant to HDMI™ with Ethernet specification version 2.0 |
• Professional quality braided cable with Metal connector head |
• Gold plated connectors for maximum conductivity |
• Supports UHD TV resolutions up to 4096x2160p @ 60Hz and HDR |
• Supports 3D resolutions up to 1080p Full HD @ 120Hz |
• Supports up to 32 audio channels for the total audio experience |
• Supports up to 1536 KHz audio sample frequency for the highest audio fidelity |
• Fully Bi-Directional |
All |
HDMI™ Male |
HDMI™ Male |
• Packaging size: 25 x 21 x 4.2cm / 9.84 x 8.27 x 1.65" |
• Poly Bag Weight: 10 gr. |
• Product Weight: 350 gr. |
• Product height: 12mm. |
• Product width: 19 mm. |
• Product Length: 5 meter/16.40 feet |
• Made in China |
Club 3D HDMI™ 2.0 4K60Hz UHD Cable 5m/16.40ft |
This Club 3D HDMI™ * cable is also suitable for: Xbox One, Xbox One S, Xbox 360, PlayStation 4, PS3, Nintendo Switch |
* Please check your TV/monitor user-manual for its required specifications and maximum resolutions. |
