The Club 3D CSV-1585 is a MST dual(HDMI+DP) display dock with KVM functionality. Two USB Type-C input for connecting two different hosts to improve the productivity between the two hosts quickly, just one click on the top button or by clicking the connected cable remote button. 3xUSB Type-A+3xUSB Type-C provide enough connection for external devices with up to 5Gbps data transfer. 120Watt DC power supply provides 65Watt Power Delivery(PD) to charge your USB Type-C laptop or host devices. Compatible with any USB Type-C port DP Alt Mode enabled devices, like Laptop, desktop PC, tablet, Phone, etc,. Support charging with PC1 and PC2 port, press the POWER SWITCH key to switch input power. Using 20V/6A 120W DC power adapter to supply power for docking station, among 65W power charging for PC2 host at the same time. Supply External power for PC1 through USB Type-C1 port, the charging power depends on the PD adapter. With Kensington lock. Plug and play.
Product Name: DisplayPort/HDMI KVM Switch/Dock 4K60Hz For USB Type-C inputs |
Product Series: Universal Docking |
Product Code: CSV-1585 |
EAN code: 8719214472870 |
UPC code: 841615103140 |
• Dual USB Type-C Inputs |
• Dual DisplayPort™ / HDMI™ Output up to 4K60Hz |
• Compatible with DP Alt Mode |
• Support KVM function |
• Dual PD connections Thru PS and USB Type-C connector |
• Support for switching LED indications |
Applications: |
• Docking station with MST functionality(On MAC systems Only SST(Mirror Screen)) |
• KVM for USB Type-C inputs |
Supported resolutions: |
• See QIG |
• Windows 10 or upwards, Mac 13.5.2 |
• 1X CSV-1585 DisplayPort/HDMI KVM Switch/Dock 4K60Hz For USB Type-C inputs |
• 2x USB Type-C Cable length approx.: 1m / 3.28 ft |
• 1x Remote Cable length approx.: 1m / 3.28 ft |
• Power Supply 100-240VAC/ 20V/6A DC 120Watt(Specify Power Plug) |
Available Interfaces |
• PC 1 USB Type-C |
• PC 2 USB Type-C |
• DC 20V/120Watt from Power Supply Unit |
• 1x HDMI™ Female |
• 1x DisplayPort™ Female |
• 1x USB Type-C PD3.0(100Watt) for charging PC1 |
• 2x USB Type-C Gen1 Data(5 Gbps) |
• 2x USB Type-A Gen1 Data(5 Gbps) |
• 1x USB Type-A Gen1 Data(5 Gbps) BC1.2 |
• 1x Headset 3.5mm Stereo port |
• Remote Switching |
• Ethernet Gigabit RJ-45 |
• Box size: 21 x 25 x 5 cm / 8.27 x 9.84 x 1.97" |
• Device size: 18.5 x 7.9 x 2.8cm / 7.28 x 3.11 x 1.1" |
• USB Type-C Male Connector dimensions: 3.62 x 1.2 x 0.63 cm / 1.43 x 0.47 x 0.25" |
• Device Weight: 248 gr / 8.75 oz |
• 2x USB Cable Weight: 36 gr / 1.27 oz |
• 1x Remote Cable Weight approx.: 24 gr / 0.85 oz |
• PS Weight approx.: 592 gr / 20.88 oz (Depending on Power Plug) |
• Box Weight: 142 gr / 5.01 oz |
• Total Weight Approx.: 1078 gr / 38.03 oz |
Warning Safe Usage – Product Only to be used at altitude 2000 meters/6562 feet and below |
- Club 3D uses environmentally friendly packaging and is printed on recycled paper |
- Club 3D uses Bio-Degradable bags according to the EN/DIN 13432 |
- CSV-1585_SPECIFICATION-SHEET_EN.pdf
- CSV-1585_SPECIFICATION-SHEET_DE.pdf
- CSV-1585_SPECIFICATION-SHEET_ES.pdf
- CSV-1585-QUICK INSTALL-GUIDE_EN.pdf
