USB Tipo-C para Ethernet y USB 3.0 + USB Type-C Charging Mini Dock
CSV-1530 El Hub SenseVision USB Tipo-C para Ethernet y USB 3.0 + USB Type-C Charging Mini Dock es muy portable y útil para el uso de su portátil con puerto USB Tipo-C o Ultrabook. El puerto integrado RJ45 Gigabit Ethernet ofrece una conexión rápida y estable a un cable de red y el puerto SuperSpeed USB 3.0 Tipo-A conecta sus barras de USB, periféricos y discos duros. Utilice la funcion de Carga Electrica en el USB Tipo-C para cargar su dispositivo de hasta 60Watts al mismo tiempo. Soporta Microsoft Windows y Apple OS X.
Model |
Product Name: USB Tipo-C para Ethernet + USB 3.0 + USB Type-C Cargar Mini Dock |
Docking Station |
Product Series: SenseVision |
Weight: 51 gr |
Connector length: 55mm |
Item Code: CSV-1530 |
EAN Code: 8719214470470 |
UPC Code: 841615100606 |
Interface |
USB 3.0 Type C male x 1 |
Output Configuration |
RJ45 Ethernet female x 1 |
USB 3.0 Type-A female x1 (for Data) |
USB 3.0 Type-C female x1 (for Charging) |
In the package |
SenseVision USB Type C to Ethernet + USB 3.0 + USB Type C Charging Mini Docking Station |
Quick install guide |
• Innovative Portable Design |
• Folding USB Type C Connector |
• Supports Gigabit Ethernet RJ45 (10/ 100/ 1000Mbps) |
• Fully compliant with IEEE802.3 and IEEE802.3u |
• 1x USB 3.0 Type-A port for Data (max 5Gbps) |
• 1x USB Type C for Charging PD (5V/ 1.5A, 20V/3A) |
The minimum requirements for the PC are: |
CPU: AMD or Intel Dual Core CPU 2GHz or higher processor clock. |
GPU: AMD, Intel or Nvidia |
RAM: 1GB or higher |
USB port: Type C 2.0/3.0 |
30MB of available disk space |
Supported Operating Systems: |
Windows 7 (32 & 64 Bit) |
Windows 8.1 (32 & 64 Bit) |
Windows 10 (32 & 64 Bit) |
Apple OS X |
And under Beta: |
Android 5.X |
Ubuntu Linux |
