Mini DisplayPort to DVI-D SL Passive Adapter
CAC-1100 The Club 3D is a passive DVI signal converter. The Mini DisplayPort™ to DVI-D Adapter is the easiest solution for connecting your Mini DisplayPort™ enabled Desktop or Laptop to a DVI enabled High Definition Television, Monitor or Projector.
The adapter works with AMD, Intel® and Nvidia® graphics solutions and supports a maximum resolution of 1920x1200p @ 60Hz. Simply connect the Mini DisplayPort™ (male) end of the connector to your computer and plug your existing DVI-D cable from the display into the DVI (female) adapter.
Setup requires no software installation. The circuitry built into the adapter seamlessly converts the Mini DisplayPort™ video signal into a DVI digital video signal.
Please note that this adapter is for digital signals only and will not fit analog DVI ports.
This professional grade adapter-cable is ceritfied by Vesa
Model |
Product Name: Mini DisplayPort™ to DVI-D Single Link Passive Adapter |
Product Series: Accessories |
Item Code: CAC-1100 |
EAN Code: 8717249408482 |
UPC Code: 854365005121 |
Features |
• Compliant to DisplayPort™ 1.1a Specification |
• Supports Dual Mode DisplayPort™ (DP++) |
• Supports resolutions up to WUXGA 1920x1200p @ 60Hz |
• Supports High Definition resolutions up to Full HD 1080p @60Hz |
• No external power needed |
• Supports AMD, Nvidia® and Intel® HD/ Iris™ graphics solutions |
• Vesa ceritfied |
Connector 1: |
Mini DisplayPort™ Male |
Connector 2: |
DVI-D Single-Link Female |
Operating Systems |
Microsoft Windows, Apple OS X |
• Boxsize:280 x 60 x 35mm. |
• Cable: 170 x 44 x 18mm. |
• Weight: 56 gr. |
• Made in China |
In the Box |
CAC-1100 Mini DisplayPort™ to DVI-D Single Link Passive Adapter |
