DisplayPort Male to DisplayPort 1.4 Female 90 Degree Angled Adapter 4K120Hz M/F
The Club 3D CAC-1008 DisplayPort Male to DisplayPort 1.4 Female 90 Degree Angled Adapter 4K120Hz M/F is a versatile angle connector adapters providing cable management solutions. With this adapter you can avoid blocking other ports on your host device. Also for displays with a tight location on the DisplayPort input this can be an easy fix for not blocking other ports and/or bending cables. This set contains 1 of adapter and is universal in their usage for supporting display resolutions of up to 4096*2160 at 120Hz or 7680*4320 at 30Hz . The adapters are verified with Club 3D products to support these resolutions. Its important that the source and display should support DP1.4 and the cables are also designed to support this bandwidth.
Product Name: DisplayPort Male to DisplayPort 1.4 Female 90 Degree Angled Adapter 4K120Hz M/F |
Product Series: Adapter |
Product Code: CAC-1008 |
EAN-Code: 8719214473129 |
UPC-Code: 841615103379 |
• 90 Degree Angle/ Upward & Downward Angled |
• Easy connection of your host cable |
• Doesn't block your other ports |
• Supports DisplayPort 1.4 HBR3 with maximum video resolution o up to 4K120Hz or 8K30Hz |
• Support DisplayPort 1.4 and downwards compatible with older versions |
• Transmissions speed 16.2Gbps /2.7 Gbps / 5.4Gbps / 8.1 Gbps |
• Minimal signal loss |
Supported resolutions: |
• Up to 4K120Hz or 8K30Hz |
• All |
Available Interfaces: |
• DisplayportPort Male |
• DisplayPort Female |
• CAC-1008 DisplayPort Male to DisplayPort 1.4 Female 90 Degree Angled Adapter 4K120Hz M/F |
• Box size: 6 x 7x 3.5 cm / 2.36 x 2.76 x 1.38" |
• DisplayPort Connector: 2.56 x 1.8 x 1.7 / 1.01 x 0.71 x 0.67 " |
• Device Weight: 13gr / 0.46 oz |
• Box Weight: 34 gr / 1.2 oz |
• Biodegradable Bag Weight: 5 gr / 0.17 oz |
• Total Weight: 52 gr / 1.83 oz |
Note: |
Please use one of our Extension/Adapter cables to connect to your devices: In case you need assistance to choose the correct cable, feel free to mail us at [email protected] and it will be our pleasure to assist you. |
- CAC-1008-SPECIFICATION-SHEET_EN.pdf
- CAC-1008-SPECIFICATION-SHEET_DE.pdf
- CAC-1008-SPECIFICATION-SHEET_ES.pdf
