USB3.2 Gen1 Type A or C Dual Display 4K60Hz Docking Station
The Club 3D CSV-1460 USB3.2 Gen1 Type A or C Dual Display 4K 60Hz Docking Station is designed to satisfy all your connectivity demands. It provides no less than 6 USB3.2 Gen1 Ports, Headphone- and Microphone- connection, Gigabit Ethernet port and 2 x Displayport™4K60Hz outputs.
It is fully USB C compatible and a USB3.2 Gen1 Type C to USB3.2 Gen1 type B cable is included in the box.
With this CSV-1460 you can now connect two screens at 3 840x2160 UHD at 60Hz resolution to almost all existing Notebooks or Tablets just by using a single USB3.2 Gen1 Type A or C port! Featuring the advanced DisplayLink™ DL-6950 chip, you can even connect one screen at a resolution of 5K at 60Hz!
The USB3.2 Gen1 Type A or C Dual Display Docking Station has a convenient design and detachable stand, allowing it to be placed on your desk in horizontal- or vertical position. It's a productivity enhancing tool for any power user working in a (semi) professional environment.
Dual Mode DisplayPort™:
The USB3.2 Gen1 Type A or C Dual Display 4K 60Hz Docking Station has 2 Displayport™++ outputs or in other words, Displayport™ 1.2 Dual Mode. This means that for the conversion of the video signal to DVI or HDMI™ passive cables or adapters must be used.
Product Name: |
USB3.2 Gen1 Type A or C Dual Display 4K60Hz Docking Station |
Product Series: Docking |
Product Code: CSV-1460 |
EAN code: 8719214470777 |
UPC code: 841615100965 |
• Portable Universal USB Gen1 Type A or C Dual Display 4K 60Hz Docking Station |
• Fully USB C compatible with USB C cable included in the box |
• DisplayLink™ DL-6950 chip inside |
• Supports dual External monitors via Displayport™ |
• Max supported resolution for Single Screen Setup: 5120x2880 @ 60Hz |
• Max supported resolution for Dual Screen Setup: 3840x2160 @ 60Hz |
• 6x USB3.2 Gen1 downstream port (BC 1.2 quick charging x1) |
• Supports Gigabit Ethernet (10/ 100/ 1000Mbps) |
• Audio: 2 x 3.5 mm Jack for Headphone and Microphone |
• Supports Windows® 8.1/10 and MAC OS X® up to v10.15 |
• Windows® 8.1/10 and MAC OS X® up to v10.15 |
• USB3.2 Gen1 Type A or C Dual Display 4K 60Hz Docking Station |
• USB A cable (USB Type A to B, 1m /3.28 ft) |
• USB C cable (USB Type C to B, 1m /3.28 ft) |
• Power Adapter (Output 20V/2.25A) |
• Quick install guide |
Available Interfaces |
• 1x USB3.2 Gen1 Type B Male |
• 1x DC 5v Female |
• 2x Displayport™ |
• 6x USB3.2 Gen1 Type A |
• 1x Gigabit Ethernet port |
• 1x 3.5mm Audio jack 2.1 ch |
• 1x 3.5mm Mic jack |
• Box size: 13 x 21.2 x 13 cm / 5.12 x 8.35 x 5.12 inch |
• Dock size (incl Base): 8 x 3.5 x 19.5cm / 3.15 x 1.38 x 7.68 inch |
• USB A to USB B Cable: approx. 1m / 3.28 ft |
• USB C to USB B Cable: approx. 1m / 3.28 ft |
• Box Weight: 200 gr./ 7.2 oz |
• Dock Weight: 395 gr./ 13.89 oz |
• USB A Cable Weight: 43 gr./ 1.52 oz |
• USB C Cable Weight: 42 gr./ 1.48oz |
• AC adapter Weight: approx. 355 gr./ 12.52 oz |
• Total Weight: 1035 gr./ 36.51 oz |
Warning Safe Usage: Only to be used at altitude 2000 meters/6562 feet and below. |
- CSV_1460_SPECIFICATION-SHEET_EN.pdf
- CSV_1460_SPECIFICATION-SHEET_DE.pdf
- CSV_1460_SPECIFICATION-SHEET_ES.pdf
- CSV-1460-Quick-Instal_How-To-User-Manual_EN.pdf
- CSV-1460-Quick-Instal_How-To-User-Manual_DE.pdf
