USB 3.2 Gen1 Type A 3-Ports Hub with Gigabit Ethernet
The Club 3D USB 3.2 Gen1 Type A Hub 3Ports with Gigabit Ethernet is designed in a stylish manner and very slim which makes it easy to carry around.
The CSV-1430 allows you simultaneous access to 3 x USB 3.2 Gen1 Type A ports and the Ethernet 10/100/1000 Port from just one single USB 3.2 Gen1 Type A up-link. The Device is downwards compatible to USB 2.0 standard, but this will have influence on the performance.
The 3 USB ports are all USB Type A and USB 3.2 Gen1 compliant. The Ethernet port is compliant to Gigabit Ethernet 10/100/1000 (RJ45) and full duplex with flow control.
In case you need assistance to choose the correct cable, please visit our
website www.club-3d.com or feel free to mail us at [email protected] and it will be our pleasure to assist you.
Product Name: USB 3.2 Gen 1 Type A 3-Ports Hub with Gigabit Ethernet |
Product Series: Docking |
Itemcode: CSV-1430 |
EAN code: 8719214470111 |
UPC code:841615100217 |
• USB 3.2 Gen1 Giga LAN with 3 ports USB 3.2 Gen1 Type A HUB |
• Small design make users easy hand carry. |
• Support wake-on-LAN function |
• Support Green Ethernet |
• Support IEEE 802.3az(Energy Efficient Ethernet) |
• Support IPV4/IPV6 pack Checksum Offload Engine(COE) to reduce CPU loading |
• It works with Windows® and Mac OS® |
• Bus-powered |
OS Support: Windows® and Mac OS® |
• CSV-1430 USB 3.2 Gen1 Type A 3-Ports Hub with Gigabit Ethernet |
• USB 3.2 Gen1 male |
• RJ 45 Ethernet female |
• 3x USB 3.2 Gen1 female |
• Box size: 14.5 x 14.5 x 4.5 cm / 5.7 x 5.7 x 1.8 inch |
• Device Size: 9.1 x 4 x 1.6 cm / 3.6 x 1.6 x 0.63 inch |
• Cable Length: 6 cm / 2.4 inch |
• USB Type A connector size: 4 x 1.5 x 0.8 cm / 1.6 x 0.6 x 0.32 inch |
• Device Weight: 51 gr / 1.8 oz |
• Box Weight: 24 gr /0.85 oz |
• Total Weight: 75 gr / 2.7 oz |
- SPECIFICATION SHEET_CSV-1430_EN.pdf
- SPECIFICATION SHEET_CSV-1430_DE.pdf
- SPECIFICATION SHEET_CSV-1430_ES.pdf
- HOW_2_CSV-1430-EN.pdf
- CSV-1430-MANUAL.pdf
