Travel Charger 240 Watt GaN technology, Four port USB Type-C, Power Delivery(PD) 3.1 and PPS Support
The Club 3D CAC-1918 Travel Charger 240 Watt GaN technology, Four port USB Type-C, Power Delivery(PD) 3.1 and PPS Support is a high-performance and fashionable design travel charger. Versatility: Perfect solution for business travelers and power users needs and multiple ports. This means you only need one charger for all your modern devices, and you don't have to worry about carrying multiple adapters.
Portability: Highly portable and easy to carry (535 gr / 18.87 oz) in a backpack or luggage, making it ideal for business travelers who need to stay connected on the go without being weighed down by bulky chargers.
Powerful charging: The 240 Watt charger charges multiple devices simultaneously at high speed, while improving the life of your batteries at the same time. Ensuring busy travelers can stay productive on the move without waiting around for hours. Built-in safeguards protect your devices against excessive current, overcharging and overheating(OCP-OTP-SCP-OVP). The unit comes with a suporting bridge to position the unit uprigth.
Travel Charger 100W GaN technology, Four port USB Type-A(2x) and -C(2x), Power Delivery(PD) 3.0 Support
USB2 Type-C Bi-Directional USB-IF Certified Cable Data 480Mb, PD 240W(48V/5A) EPR M/M 1m / 3.23 ft
Product Name: Travel Charger 240 Watt GaN technology, Four port USB Type-C, Power Delivery(PD) 3.1 and PPS Support
Product Series: Power
Product Code: CAC-1918
EAN-Code: 8719214473068
UPC-Code: 841615103324
• Internal chip allows the 100-240VAC of input voltage.
Four USB Type-C connectors for outputs:
• All-port:     Total: 240W MAX
• Accurate limited current output and over current protection(OCP)
• Overload protection and over voltage protection(OVP)
• Short circuit protection (SCP)
• Over temperature protection and remove the fault condition auto-recovery(OTP)
• Compliant with CE, UL, FCC, DOE, CEC, NRCAN standards.
• Selected precision electrical components, fire line version
• Portable and convenient to use.
• Specially designed for your Type-C supported devices.
• Windows 10 or upwards, Mac OS 14.4.1
Available Interfaces:
• 1x Mains cable (Specify on Order) 100-240VAC 50/60Hz
• 4x USB Type-C Femal
• 1x CAC-1918 Travel Charger 240 Watt GaN technology, Four port USB Type-C, Power Delivery(PD) 3.1 and PPS Support
• 1x Supporting bridge(to position the unit uprigth)
• 1x USB Type-C EPR 5A cable RED (Power ONLY) 1 m / 3.28 ft)
• 1x Power cable( 1.5 m / 4.92 ft) Please specify plug when ordering
• Box size: 17.5 x 17.5 x 6 cm / 6.89 x 6.89 x 2.36"
• Device size: 12.2 x 8.8 x 3.5 cm / xx inch "
• Device Weight: 535 gr / 18.87oz
• Power Cable length approx.: 1.5 m / 4.92 ft
• Power Cable Weight Approx.: 154 gr / 5.43 oz Depending on Power plug
• USB Cable Weight: 35 gr / 1.2 oz
• USB Type-C EPR 5A cable RED (Power ONLY) 1 m / 3.28 ft
• Box Weight: 70 gr / 2.47 oz
• Bio Degradable Bag size: 15 x 15 cm / 5.9 x 5.9"
• Bio Degradable Bag Weight: 4 gr./ 0.14 oz
• Total Weight: 823 gr / 29.03 oz
Warning Safe Usage - Product Only to be used at altitude 2000 meters/6562 feet and below.
Club 3D uses Bio-Degradable bags according to the EN/DIN 13432.
No extra information found.
