VGA Cable Bidirectional M/M 10m/32.8ft 28AWG
The Club 3D CAC-1710 VGA Cable Bidirectional M/M 10m/32.8ft 28AWG links any VGA-equipped desktop, laptop or adapter to a monitor, display, beamer or projector with a 15-pin VGA Female port. Ideal for at home or work, the cable creates a reliable connection for anything from gaming to video projection and supports up to Full HD 1080p(max. resolution of 1920 x 1080).
This quality VGA cable provides superior performance thanks to the combined effect of its Gold plated connectors and 28 AWG conductors. Internal shielding provides reduced crosstalk, suppresses noise, and helps prevent electromagnetic interference (EMI) and radio frequency interference (RFI).
Experience a reliable, high-quality connection with this convenient VGA to VGA 10m / 32.8ft cable.
Product Name: |
VGA Cable Bidirectional M/M 10m/32.8ft 28AWG |
Product Series: Cable |
Product Code: CAC-1710 |
EAN code: 8719214472191 |
UPC code: 841615102433 |
• Standard 15-pin VGA Male to VGA Male cable |
• Inner conductor: 3 x coax (RGB) |
• Gold-plated connectors |
• Shielded for EMI/RFI interference |
• Resolution up to 1920 x 1080 (Full HD 1080p) |
Supported resolutions: |
• All |
• CAC-1710 |
Available Interfaces |
• VGA Male |
• VGA Male |
• Box size: 23 x 23 x 5 cm / 9 x 9 x 1.97 " |
• Cable length: 10m / 32.8ft |
• Connector dimensions: 4.4 x 3.3 x 1.6 cm / 1.73 x 1.3 x 0.63" |
• Cable Weight: 821 gr / 28.96 oz |
• Box Weight: 93 gr / 3.28 oz |
• Total Weight: 914 gr / 32.24 oz |
- CAC-1710_SPECIFICATION-SHEET_EN.pdf
- CAC-1710_SPECIFICATION-SHEET_DE.pdf
- CAC-1710_SPECIFICATION-SHEET_ES.pdf
