• DESIGNED FOR LONG RANGE: Hybrid Active Optical HDMI™ 2.1 Cable delivers 8K60Hz beyond the length of standard copper cables, The fiber optic inner cores greatly reduce EMI for optimal signal quality and minimal degradation. Note: Cable is unidirectional
• PLENUM RATED: Ultra High Speed HDMI™ Hybrid AOC is Plenum-rated (CPR) for safe installation in plenum spaces, Suitable for ceiling, conduit, and in-wall cable runs, For use in commercial environments where compliance with fire codes(EN50575:2014+ A1:2016 / EN 13501-6:2014) must be considered
• VERSATILE PERFORMANCE: Full-featured HDMI™ 48Gbps enables Dynamic HDR processing for vibrant picture quality, 7.1 and 32-ch audio w/eARC, Ideal for video walls, conference rooms, and dedicated video/media devices, Compatible with lower HDMI™ 2.0/1.4/1.2 specs
• QUALITY CONSTRUCTION: Shielded gold-plated connectors rated beyond 10,000 insertion cycles, Optical fiber core reinforced strands for tensile strength, Tested beyond 6,000 bending cycles at 120°, Labeled connector ends for Source and Display
• SPECS: Black, 50 m / 164.04 ft, Unidirectional, CPR Certified, Ultra High Speed HDMI™ supports FRL/HDR/DSC 1.2a/HDCP, EDID, CEC, DDC, Audio, 48Gbps, 8K60Hz/4K120Hz, 32 AWG, O.D.4.8mm/0.19in, Ideal for long cable runs
Product Name: |
HDMI™ Hybrid AOC Cable 8K60Hz/4K120Hz 50m/164.04 ft |
Product Series: Cable |
Product Code: CAC-1393 |
EAN code: 8719214473464 |
UPC code: 841615103713 |
• Fully Compliant to Ultra High Speed HDMI™ specification |
• Professional quality cable |
• This cable is Uni - Directional because its an Active Cable. |
• Backwards compatible to previous HDMI™ versions |
• All |
• 1x CAC-1393 |
Available Interfaces |
• 1x HDMI™ 2.1 |
• 1x HDMI™ 2.1 |
• Box size 21 x 21 x 7.5cm / 8.27 x 8.27 x 2.96in |
• Cable length approx.: 50m / 164.04ft |
• Connector dimensions: 4 x 1.8 x 0.8cm / 1.57 x 0.71 x0.32in |
• Product Weight: 1183g / 41.73oz |
• Box Weight: 112g / 3.95oz |
• Bio Bag Weight: 6g / 0.21oz |
• Total Weight: 1301g / 45.89oz |
- CAC-1393-SPECIFICATION-SHEET_EN1.pdf
- CAC-1393-SPECIFICATION-SHEET_DE1.pdf
- CAC-1393-SPECIFICATION-SHEET_ES1.pdf
