CAC-1310 The Club 3D HDMI™ 2.0 High Speed 4K UHD cable enables the connection of your HDMI™ 2.0 supported Gaming PC or Laptop to an (Ultra) High Definition Monitor or other HDMI™ 2.0 supported device. It fully supports the ‘HDMI High Speed with Ethernet’ specification, ensuring that video up to 4K UHD 3840x2160p at 60Hz is supported, as well as HDR, audio and data streams. The cable combines the unmatched signal quality and convenience of HDMI™ connectivity with the power and flexibility of home entertainment networking. It includes a dedicated data channel into the HDMI™ link, enabling high speed networking at up to 100 Mbps. It is the ideal solution for the ultimate future proof HDMI™ 4K UHD Gaming and Viewing experience.
Premium High Speed HDMI™ 4K60Hz UHD Cable M/M 1 m / 3.28 ft 30AWG
Product Name:Premium High Speed HDMI™ 2.0 4K60Hz UHD Cable 3 m/ 9.84 ft
Product Series: Cable
Item Code: CAC-1310
EAN Code: 8719214470449
UPC Code: 841615100569
• Compliant to Premium High Speed HDMI™ with Ethernet specification
• Professional quality cable 30 AWG
• Supports HDMI™ 2.0 specification
• Backwards compatible to support HDMI™ 1.4 specification
• Fully Bi-Directional
• Supports (U)HDTV resolutions up to 3840x2160 @ 60Hz and HDR
• Supports 3D resolutions up to 1920x1080p Full HD @ 120Hz• Total Data throughput of 18Gbps, three lanes, 6Gbps per lane
All
Connector 1:
HDMI™ Type A male
Connector 2:
HDMI™ Type A male
Other Info:
• Boxsize: 190 x 190 x 65 mm.
• Product Weight: 200g
• Product Size: 3000x20x10 mm
• Meets ROHS and FCC requirements
In the Box:
Club 3D Premium High Speed HDMI™ 2.0 4K60Hz UHD Cable 3 m/ 9.84 ft
-HIGH DEFINITION AND MORE
POSSIBLE RESOLUTIONS
