The Club 3D CAC-3025 is a 2-Pack USB-C® Charger which provide 30Watt Power Delivery 15V/2A.  This product is a high-performance travel charger with 30Watt output at most. Supports both iPhone and Android(with an USB-C® connector) It is compatible with various USB protocols (such as iPad, iPhone and other tablets and smart phones). Precise current-limiting output, overload protection and automatic restart after troubleshooting make the product safer and give you more peace of mind. Supports various Charge protocols (iPad, iPhone, Android, etc.) It is helpful for long-distance travel as well as convenient for business as they come in a 2-Pack version and different colors!
2-Pack USB C Charger 30 Watt Blue
2-Pack USB C Charger 30 Watt Green
2-Pack USB C Charger 30 Watt Pink
Product Name: 2-Pack USB-C® Charger 30Watt
LIFESTYLE
Product Code: CAC-3025
Color: Purple
EAN Code: 8719214473440
UPC Code: 841615103690
• Supports both iPhone and Android (with an USB Type-C® connector)
• Power Delivery up to 30Watt(15V/2A)
• Supports various Charge protocols (iPad, iPhone, Android, etc.)
• Available in different colors
• Power Delivery(PD) 3.0 Support
• Accurate limited current output and over current protection (OCP)
• Overload protection and over voltage protection (OVP)
• Short circuit protection (SCP)
• Over temperature protection and remove the fault condition auto-recovery (OTP)
• Compliant with UL, CE and FCC standards
• Light weight and convenient to use
• Windows 10 or upwards, macOS 15.0, Android OS
• 2x CAC-3025  USB-C® Charger 30Watt Purple
• AC power plug
- Internal chip allows 100-240VAC input voltage range
• USB-C®
- 5V/9V3A, 15V2A Power Delivery (PD3.0)
- Total output 30Watt Max
• Box Size approx.: 10 x 10 x 3.5 cm / 3.94 x 3.94 x 1.38 in
• Device size approx.: 8.8 x 4 x 2.3 cm / 3.46 x 1.57 x 0.91 in (Depending on plug)
• One Device Weight: 60 gr / 2.12 oz
• Bio Degradable Bag size approx.: 13 x 21 cm / 5.12 x 8.27 in
• Bio Degradable Bag Weight: 3 gr / 0.11 oz
• Meets ROHS and FCC requirements
Club 3D uses Bio-Degradable bags according to the EN/DIN 13432
In case you need assistance to choose the correct cable, please visit our website
www.club-3d.com
or feel free to mail us at [email protected] and it will be our pleasure to assist you.
Some external devices, like the computer mouse, also need some power from the USB Port to operate. This power can be delivered through standard USB connection. The Default Power that USB 1.0 and 2.0 can deliver is 2.5Watt (5Volt, 0.5A), USB 3.0 and 3.1 can deliver 4.5Watt (5V, 0.9A), USB 3.2 can deliver 7.5W (5V/1.5A) and USB 4 can deliver 240Watt. For the external devices requiring more power, different technologies have been developed. It is important to distinguish following 2 technologies: "USB Power Delivery" and "USB Battery Charging".
