Mini HDMI to HDMI 4K60Hz Cable M/M 1 m/ 3.28 ft
CAC-1350 The Club 3D Mini HDMI™ to HDMI™ 2.0 Cable delivers an UHD resolution signal for clear, natural pictures and sound. It enables you to connect your Digital Camera/Camcorder, Mini PC, Pico Projector or other device with Mini HDMI™ output to a 4K UHD TV, monitor or projector with HDMI™ input. It fully supports the Premium High Speed HDMI™ with Ethernet specification, ensuring that video up to 4K UHD 3840x2160p at 60Hz is supported, as well as HDR, audio and data streams.
The Mini HDMI™ to HDMI™ 2.0 Cables are premium quality making them ideal for use with (Semi) Professional equipment supporting Ultra High Definition Resolutions.
Maximum resolution: |
3840x2160p @60Hz and 1920x1080p 3D video @ 120Hz |
Connector 1: |
Mini HDMI™ male |
Connector 2: |
HDMI™ male |
Model: |
Product Name: Mini HDMI™ to HDMI™ 2.0 Cable, 4K 60Hz 1 Meter/3.28 Feet Male/Male |
Product Series: Accessories |
Weight: 55gr |
Cable length: 1 meter/ 3.28 feet |
Item Code: CAC-1350 |
EAN Code: 8719214470661 |
UPC Code: 841615100842 |
• Fully compatible with HDMI™ 2.0 Standard |
• Backwards compatible with earlier HDMI™ versions |
• Compliant to Premium High Speed HDMI™ |
• Video Resolutions Support 4K at 60Hz HDR |
• Supports 3D video resolutions up to 1920x1080 full HD at 120Hz |
• Plug & Play and fully Bi-Directional |
Windows |
In the Box: |
Club 3D Mini HDMI™ to HDMI™ 2.0 Cable, 4K 60Hz 1 Meter/3.28 Feet Male/Male |
- CAC-1350-SPECIFICATION-SHEET_EN.pdf
- CAC-1350-SPECIFICATION-SHEET_DE.pdf
- CAC-1350-SPECIFICATION-SHEET_ES.pdf
